Results 1 to 3 of 3
    Exclamation 2009 MKS FWD Brakes
    Does anyone have the bolt torque specs for the front and rear brake caliper slider bolts and caliper bracket bolts? I can't find anything on the web, and I need to get this done ASAP.
    - CA car, 5.0 w/5 speed
    2008 Taurus I found this:
    "Caliper mounting bolts front: 23-28 ft/lbs. Rear: 23-25. Caliper mounting bracket bolts: 65-87 ft/lbs."
    I am sure that will get you in the ball park.
    Be sure to apply lock tight
