Results 1 to 4 of 4
    FEP Senior Member 9DBlackMagic's Avatar
    Sep 2006
    Antioch, California
    Default 87-89 1/4 Panels
    I have a buddy that wants to put a set in his 86. Do these fit with no modifications. If so what do you have to do?
    ~LES~
    157 HP @ 4200 RPM
    240 ft/lb @ 2400 RPM
    Capri:
    No they do need some modifications.
    The area around the quarter window is deeper/longer than the 79-86 panels and generally requires @ 3/4" to be trimmed off. The rest is essentially a bolt in, although the screw holes are often in different locations. If using the 87-89 panels the seat belt mount hole should line up. Not a difficult install, just takes a bit more work to fit properly.
    Sep 2006
    Antioch, California
    Thank you Trey
    ~LES~
    157 HP @ 4200 RPM
    Capri:
    Glad to help! Good Luck!
