Results 1 to 25 of 28
    Default Head swap for budget build - lifters
    I'm pretty dead set on doing a head swap for my Fairmont Budget build. However this is 100% new to me. I've done some research, but it's really looking like it will end up being spring by the time I do this, but I have a question I need help understanding.
    Plan is to keep stock cam. Get some GT40 heads rebuilt at machine shop (3 angle valve job, surfaced as necessary, valve stem seals replaced). Keep stock springs as I'm running stock cam, but spend money on roller rockers.
    What would the risk/bad practice be if I replaced everything from the pushrod up, but not the lifters? Leave the lifters that are currently in car right now? I can see the obvious reason as to why to replace them, the current ones would have wear on them, and I'm down there, and it's good practice...but the other part of me sees it as why mess with one other factory part, and an opportunity to not fix something that's not broken and help me stay on track with the total budget if I don't have to buy something else.
    If you could help me put into perspective how foolish it would be to leave the stock lifters in place I would appreciate it.
    Being that you say the car is a Fairmont I'm going to assume that you have flat tappet lifters. Roller lifters can be reused without issue. For flat tappet lifters, I would take each one out at a time and inspect for wear. If they look good I'd reuse them.
    Don't forget to look at the lobes on the cam too.
    Jess
    Previously owned;
    Jess you beat me to it. Rollers are fine as long as they are ok , but flat tapped lifters are actually rotated by the cam as well as going up and down. It's good practice to replace them with a cam change, as they "seat" to the cam.
    Hey thanks both of you for the replies. I assume too that it's not a roller equipped motor either. Eventually I'll get that confirmed for sure before I purchase anything. So a flat tappet lifter that has excessive wear, I assume that's a concave shape on the face of it?
    Yes. That's why non roller cams generally come with lifters. At least the ones I have bought did.
    Explorer GT40 heads do not have enough spring for a stock HO cam
    Jul 2010
    Houston (Clear Lake), Texas
    Leave the lifters alone if good and invest in better spring pressure...however you want to accomplish that...
    HAD
    HAVE
    FEP User bkm's Avatar
    Jan 2016
    House Springs MO
    Flat tappet cams and lifters have to be changed, and broken in as a unit. If you're staying with the stock cam, just bolt the gt40 heads on and go. I wouldn't waste money on springs or rockers for a 79 flat tappet cam.
    Quote Originally Posted by bkm View Post
    That was my thought as well. Springs should be fine. Been doing some number crunching lately, hoping I can keep the GT40 heads in the build, but things are evaporating quick!
    Apr 2008
    Waikoloa , Hawaii
    If you do remove the lifters to inspect, make sure you put them back in the exact same hole..
    You may need differently length pushrods, particularly if the heads get deck much. You can always measure the sweep with the ones you have to find out before you order different ones.
    1986 CHP SSP Coupe
    Thanks for the tips...makes sense about the lifters since they create their own groove. I'll probably leave untouched, but we'll see. Also i saw on 302budgetbuild.com how they make a push rod measuring tool.
    So here's where my list is at for the moment:
    AFR head bolt kit - $48.81
    Fel Pro Head gaskets - $47.98
    JEGS brand Push rods - $99.94
    Rocker channels - $22.97
    Roller rockers - anywhere between $143.99-$196.99
    So after $300 on machining (went to two different places and they quoted me about the same around here)...
    That's a total of $663.69-$716.69 on top of the cost of the heads. So curious where else you guys think I might be able to find other savings?
    Honestly....... even a Stock head with a decent intake and other parts is good for 6250 RPM. That will either hold or it won’t — considered sorta not recommended with stock rod bolts.
    Meanwhile the physics behind a 3” stroke says normal hardware is fine up to around 7000.
    Here’s the thing — Add more CFM with GT40 or other heads, and air pumps do what air pumps do — MORE and FASTER
    If you do t swap out the shortblock shut it down early because it will want to spin a lot higher than is advised. 7000+ if things are right with the CFM expected.
    You can choke that down with restrictive intake or exhaust but it negates the purpose of the swap. You can throw longer intake runners at it to create port velocity based limits. Those change slightly with things like unequal shorties on the exhaust side driving down port velocity. Long tubes long runner will go high on velocity first.
    More velocity adds area down low at the expense of upper RPM gains. Upper RPM is where the fun is at — that’s where the gains will be huge.
    All ARP in the bottom end if you do the Block swap is cheap insurance. Balance it too if you can...
    Everyone always talks about big power big displacement. Nobody ever talks about high power high RPM and honestly there are certainly good use cases for it. Street cars and road course cars that love RPM are THE BOMB when you drive them.
    Assuming 2.73 gear and a normal foxbody 3.35:1 T5
    5300 rpm rev cap due to breathing — 1-2 shift at 45, 2-3 at 70, 3-4 at 115, 4-5 at 150
    6250 RPM rev cap due to limiter — 1-2 at 55, 2-3 at 80, 3-4 at 125, 4-5 at 170 (lol)
    Then you throw a T5Z gear set at the 2nd motor
    6260 RPM rev cap - 1-2 at 61, 2-3 at 88, 3-4 at 134, 4-5 at 170
    These are about what they are..... tire size and other stuff factors in, use an RPM calculator and your gears
    Bigger than the top speed in each gear is where in the power band for the motor is when you pull the next gear and you’re running 1000 RPM more, etc
    Somebody forgot to tell my worn out E6 Head 302 in my 500K mile 86GT that it’s not allowed to make power up top. SO much fun. 0-60 comes in well under 5 seconds all in first gear......
    To steal a line from Steve — it dominates.
    you can shim the lifters or put in thread in oil galley plugs and jack up the oil pressure to avoid collapse. Valve control determines output and longevity.
    Jan 2016
    House Springs MO
    Quote Originally Posted by Str8sixfan View Post
    Use the stock rockers and pushrods. IMO, for such a stock build, it's money that can be spent elsewhere.
    On the pushrods - what’s the expected RPM range? Deflection kills power big time.
    Jan 2016
    House Springs MO
    Judging by the stock 78 cam, 4000 rpm probably. Personally, I think the stock stuff will be just fine unless there is a camshaft upgrade.
    I really appreciate your guys' input. Learning quite a bit. At the moment, the heads I purchased didn't come with rockers. I'm trying to unload them and start from scratch, but that's partially why I'm planning on buying rockers. I thought pushrods were fairly cheap reassurance since I probably am not smart enough/have a skilled enough eye to notice if stock pushrods were slightly bent or not, and also assumed that something about the pushrod length would likely have to be tweaked due to different heads (potentially some decking) and they're swapped all together...maybe buy a different head gasket thickness over stock by accident that it would just be best left to measure push rods and buy new.
    Also I'm really pushing the head swap for a few reasons:
    1) stock motor has such low compression, this is a great way to combat that
    2) it's out of my comfort zone so I believe best way to learn
    3) it's unconventional which I think makes for a better YouTube video, and am crazy enough to try it
    3a) want to demonstrate what someone can do with limited access to space/tools...as I'm running the numbers I'm probably better off doing a motor swap after U-Pull-It runs a special weekend...but I really don't have the space for a motor swap, or an engine hoist. I know I could probably rent an engine hoist, but again trying to make it relatable to the driveway mechanic. It's like a half step past bolt-on king.
    Re - read all of this. The GT40 springs are plenty strong for a non-roller (flat tappet) HO style cam. The concern was with the lift and duration of a stock HO roller that the explorer springs would be too lazy to control the valves due to the added inertia of the roller lifter going up and down more.
    You will pick up a lot with a good intake and headers and those heads. Especially if you shave them down enough to get your compression up in the range of 9’s to low 11’s.
    Just keep your RPM down - at or under 5500 - so it stays together and you can enjoy it.
    FEP Member brianj's Avatar
    Feb 2012
    Raymond, New Hampshire
    Blog Entries
    2
    If this is a flat tappet 79 motor, I believe you can also reuse the head bolts and save $50. They are not stretch bolts like newer ones. The original bolts from my '83 motor are happily holding the GT40P heads down on a '96 5.0 with 9 pounds of boost.
    Hey, good pointer brianj...I'll have to confirm that somehow to move forward with it...but at least I know what to/how to double check to figure that out!
    The gt40 heads spring pressures may be too high for a hydralic cam as it was meant for a roller one would think?
    This is the budget build I should have done.
    Str8Six,
    Look around on Craigslist and Facebook Marketplace for a good used engine hoist and stand. I did that and I was able to purchase a Hoist and stand for the same cost of renting (Half the cost of buying new).
    I could now sell both and get my money back.
    Which if you think about it, it lowers your total cost for the upgrade and keeps you from having to find space to store it...
    When you have kids, you will find yourself saying things you'd never thought would ever need to be said. Ever. The other thing you will notice, is how often you will say them.....
    Quote Originally Posted by MOOSH View Post
    Str8Six,
    It also makes the hobby cheaper for someone else too! Awesome!
    Curious to get y'all's feedback on a friend of mine's concern. I think it's valid, but not maybe as highly likely as he makes it out to be...
    So if I put on these heads, I'm doing it intentionally to up the compression ratio. But he's worried about my 40yr old bottom end. That I might damage more in the bottom end by doing this. Yes I understand the risk. Sounds like there would always be a risk, but from what I'm finding this car has been kept in really good shape, and that usually engineers build in tolerances for failure. Since I'll be keeping the pistons stock, yes I'm upping the compression ratio from stock but I can't imagine (I believe it's like 8.4:1 for the 7 that the head swap won't really push it that much further north (like I doubt I'd clip 9:1) unless I really deck the things.
    What are your thoughts? If it was you, would you worry about spinning a bearing just from a head swap?
    How many miles are on the engine in question? Higher the mileage the more likely you will want to at least do a basic rebuild. That can be as simple as new bearings, rings, seals, etc. if the bore taper isn't too bad and everything is in decent shape.
    Your stock engine should use @ 68-70 cc heads and have @ 8.4:1 compression. Depending on which GT40 heads you end up with will determine your final compression ratio. The GT40/GT40P heads can be 65-59cc before any surfacing. So you will see a compression increase, but nothing major in regards to detonation.
    Your issue using the stock short block will probably have more to do with piston ring blow by and possible oil consumption more than spinning a bearing or something. Obviously that assumes your short block isn't on it's last leg. New heads with good seals, valve job, etc. compared to possibly worn heads/seals/valve guides/etc. will put more stress and pressure on the rings which would most likely be the first thing to go with a worn out engine.
    1984 SVO Awaiting Restoration
