Results 1 to 12 of 12
Thread: rear main seal
    Default rear main seal
    Does the motor have to come out of 79 pace car to fix rear main seal? Would a mechanic at a Ford Dealership be able to handle it? Seems like nobody is comfortable with this job.
    FEP Member 83GLCoupe's Avatar
    Jul 2005
    Syracuse, New York 13211
    I would think you can do it on a lift or in the driveway. You have to remove the trans and flywheel then you'll have access to the rear main. That's if you have a one piece rear main. Not sure on the '79
    -1983 Mustang GL Coupe 9D Polar White (Sold)
    -1992 Mustang LX 5.0 PM Bright Calypso Green
    -2019 Jetta SEL (DD)
    -1982 Oldsmobile Cutlass Brougham (Wife's Toy)
    -2012 Nissan Xterra
    1979 is two-piece
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    Jul 2005
    Ah, that would explain why nobody wants to touch it. Sorry I didn't know. Ignore my post.
    -2012 Nissan Xterra
    One-piece wasn't until four months after the 1983 model year started.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Oct 2014
    Calgary, Alberta, Canada
    It's not impossible to do with the engine in, but getting the pan off is a tight fit. The engine would need to be jacked up off the mounts as high as it can be for clearance. Dropping the transmission out will make it a lot easier to get the pan out too, but then you're getting close to the same time and work as pulling the engine. It was a lot easier with the older cars with the front sump as the pan was much easier to get out.
    Thank you for the feedback!
    How many hours roughly would this job take?
    If I pulled the transmission and flywheel, would I still have to take off the oil pan?
    Quote Originally Posted by radartek View Post
    Yes, because the 2 piece seal has to be installed with the rear main cap. The one piece seal can be installed and removed with the main cap in place and therefore with the oil pan on.
    Oct 2004
    Ann Arbor MI
    this popped up today that it may help
    https://www.youtube.com/watch?v=WSy5hywk_ls
    wish I'd known this before I did my head repair!!
    Current FEP:
    Past FEP:
