Results 1 to 10 of 10
    Default Holley 4180 fuel pressure
    I am working on my '85 Capri RS fuel system. Can anybody tell me how much fuel pressure a 4180 likes to see? I am running an 80 gph Holley mechanical pump. Holley says it doesn't need a regulator but I have a feeling I am going to need one.
    Jan 2005
    Cordova, TN
    6 or 7 psi is enough.
    Yeah I was thinking maybe the new fuel pump was putting out too much pressure. I need to make up a gauge and see where it is at.
    Jul 2010
    Houston (Clear Lake), Texas
    Is the fuel return line off the pump back to the tank in working condition?
    HAD
    HAVE
    Well with the Holley pump it doesn’t have a return provision. A little back story on the set up. I pulled the motor and put on a different set of heads and cam. I switched the factory fuel pump to the Holley 80gph pump and now the car won’t idle and is fouling out the plugs. I have a 600 double pumper That will be going on, I just put the stock carb back on to get it fired up and running.
    5-6psi... or lower, and bigger needles and seats for adequate fuel delivery without frothing in the bowls from excessive pressure, is best. The quick and easy way to tell if you have excessive fuel pressure is to look at the float/fuel levels in the float bowls after the pump change. If they were previously correct and now they are higher, because the floats need to exert more pressure upward to shut off the incoming fuel... there's your issue. Does the car have or still have a return provision, a return line to the tank? Find out what the as is dead-heading pressure of the way it is now is, and if it's too much, make your own damn return between the pump and carburetor with a T with a sized restriction (1/16", 1/32", etc) inside it, connected to your return line... see my build thread for how I made one for with a low pressure in-tank electric fuel pump to get the fuel pressure exactly where needed.
    Cool, I’ll check that out. Thanks.
    Hooked the regulator last night. After messing with the car I finally got it to idle. Still isn’t even close to being right, but it is a start. For some reason the regulator doesn’t want to let me adjust the fuel pressure much. I had it at 5 now I can’t get it to adjust back up to 5. Kinda has me thinking the regulator is junk, which would be just my luck
    Quote Originally Posted by Adriver View Post
    Get a good autometer gauge. I have a reg and gauge installed on my holley equiped 302 that stays on the car. Great for diagnosing problems sometimes.
    Mine is set to 6psi. If you change pressure recheck floats every time.
