Ok I feel like I am going to snap this in half?
How does that piece above the glove box come off?
The solid painted piece with dash vents......
Thank you!
Thank you!
There are two self threading nuts that hold it on by the two plastic posts molded into the part.
Yes, if you pull hard enough you will destroy it.
Take the glove box out and you may be able to get your hand up there to feel around.
-Mike
What he said.
If you drop the glove box door, you can look up under the dash and see the plastic posts and (I think) stamped steel nuts coming through the dash in front of the heater ducting. DO NOT try to pry the panel off. It won't come off that way without breaking.
'83 Mustang GLX---T-Tops, 5.0 EFI/TKO600/8.8, Ebrock hds/int, F303, 4whl discs, 3.27s, 70mm turbo @16psi.
Yup, I was able to get in there to get them off but its tight and the outside one is a pain in the a$$ spot to get.
84 LX Convertible
1965 289 C.I.(go boom!!, 302 roller on the way)
C-4 tranny
Cool.....thanks 2 u both!
on my old 85 I reattached it with velcro. It was too big a pain to pull it and I didn't want to ever do it again.
