Results 1 to 16 of 16
    Jul 2016
    Duncannon PA
    Default EECIV code reader
    Are there any code readers still out there and available for our old four eye computers? I wouldnt mind having one since the Saleen and SVO both have this system.
    Current Mustangs
    1966 6 cylinder coupe
    1984 SVO 9W
    1985 Saleen #132
    Quote Originally Posted by dagenham View Post
    I have this one: INNOVA 3145 Ford Digital OBD1 Code Reader https://www.amazon.com/dp/B000EW0KHW..._YDUPBb63MWCFY
    And the extension cable: INNOVA 3149 Extension Cable for Ford Code Reader (Item 3145) https://www.amazon.com/dp/B000EVYH36..._gFUPBbCC0MBFX
    I use a paper clip and a test light. All the xide reader does is beep...
    Autozone sells a reader that displays the code digitally and it comes with a book that says what the codes mean. Not a bad option.
    Jul 2016
    Duncannon PA
    That sounds like a better option.
    Current Mustangs
    1984 SVO 9W
    1985 Saleen #132
    Didn't know anyone had ever made one that was semi-useful. That does sound like a good option. All mine does is flash a light in a slow or fast fashion and then repeat it 3 times. You have to be darn sure paying attention to read it so you don't get lost in all the light flashing, LOL. it goes ** * * * **** * and that would be a code 2341. It is HARD to follow at times! HaHa.
    That’s why I like the digital readout. I have an old flash and tone style one too. Much harder to use.
    -- James
    My four eyed foxes:
    past foxes -
    I just record it as a short video on my phone. Then I can rewatch it all I want.
    One of the mechanics at my work had an old snap on code reader for old Ford's. It did show the codes on a digital display, but it waited until the codes were all done flashing before it displayed them. It did have a button for starting the engine cylinder balance test. Guess that's slightly easier then tapping the gas pedal.
    Jul 2009
    Chicago, south subs
    I have the Autoxray Code Scout 2500. Had it for about 10 years now. It has OBD I cables for Ford, GM, Chrysler and the OBD II plug. It displays(text) any found codes on a small screen. Not sure if it's still being made. I've always found these things just point you in the right direction when diagnosing a problem, without 'telling' you the exact issue. Though sometimes, it's right on the money.
    Jul 2009
    Chicago, south subs
    apparently, it is still available: https://www.amazon.com/AutoXray-AX25.../dp/B000IX84KC
    I use that autozone 30 dollar version and it is awesome for what it is. I would have given up ages ago without it.
    My local oreillys has a Bosch scanner with an OBDI Ford EECIV connector I use for now. It pulls engine codes for KOEO and KOER
    Sent from my Alcatel_5044C using Tapatalk
    Forgot to mention it also has a wiggle test function. A few others but they don't work.
    Quote Originally Posted by DougTx View Post
    This is the one I have. I had the previous version with the flashing light but traded up as I had trouble figuring it out. I would like to find one for my BlueDriver.
    Code scanner or the stuff and know how to rig up a light is pretty much a don’t leave home without it. The scanners are getting harder to come by when needed and the frequency of problems is bound to increase as these cars age.
    Apr 2008
    Waikoloa , Hawaii
    Name:  Check Engine Test.jpg
    1986 CHP SSP Coupe
