Results 1 to 2 of 2
    New User
    Mar 2015
    Mechanicsville Maryland
    Default 89 LX Sunroof ??
    89 LX Factory sunroof leaking. Plan to remove and reseal, as well as clean and repair drains. Have seen the replacement weatherstrip kits fro LMR and so. Just show two cut to fit rubber strips. Is that all that is required?? Or is another gasket or seal needed??
    There are the two seals/gaskets that you mentioned. There is the seal on the sunroof glass itself and then there is a sunroof to body gasket. The other thing to check is the drains to make sure they are clean, clear, and draining any water away from the sunroof drain channel otherwise you will get leaks generally even with new seals. Good Luck!
