Results 1 to 2 of 2
    Default Lower Torque box reinforcement
    I have some questions about lower torque box repairs. 1) Are the aftermarket torque box plates worth it? They bolt in and can also be welded.
    2) What type of welding should be used to stitch weld the torque box area and repair cracks?
    Lots of options.... good welding, lol
    AFAIk, the least expensive option at small scale that will produce a bead that will work well is flux core wire feed.
