Results 1 to 4 of 4
    FEP Supporter vdubn's Avatar
    May 2017
    Beaverton, Oregon
    Default Yukon 5 Lug 28 Spline Fox Body Length Axles - SN95 hubs for Disc Brakes
    SOLD
    I have a like new set of Yukon 28 spline axles from my recent upgrade to 31 spline axles. These are 5 lug, high strength steel axles that are Fox Body length, so you can convert to 5 lug without adding any track width. The hubs are SN95 so you can run the Cobra or any SN95 rotors.
    These have 250 miles on them, and are in like new shape. I also have new axle bearings and seals that can go with.
    $175
    would you be willing to ship? if so price shipped to 48629
    Jordan
    current:
    82' Mustang GL 10.21@71 MPH 1/8 mile
    2007 Ford F150 Supercrew (DD)
    1969 ford bronco half cab (Off Road Project)
    Past:
    00' focus
    85' mustang LX
    79' F-250
    May 2017
    Beaverton, Oregon
    Sure thing... I can do $200 shipped for the axles, bearings and seals.
    May 2017
    Beaverton, Oregon
    Have had a couple people interested, but no commitments
