Results 1 to 6 of 6
Thread: Rear taillights
    Default Rear taillights
    Hey guys restoring 2 sets of taillights. They are all wet sanded and ready for paint however I noticed the backup lens is starting to peel away from base. You can see edge of lens. What do you guys recommend in between lenses to seal and hide that edge.
    Was thinking of taping everything off and using a thin layer of flex seal. Then sand and top with black base before clearing.
    Jul 2010
    Houston (Clear Lake), Texas
    What year style are you working on?
    HAD
    HAVE
    1982 sorry guess thats pretty important
    Jul 2010
    The lens will separate from the body. It sounds like the adhesive and/or caulk is failing. You have a picture of it?
    HAD
    HAVE
    If the white backup lens is loose, can remove and reglue with 3M #03601.
    Yeah it is white lens. What would you guys use to clean up the edge. Or would I just pull it, seal it back to frame, and then basecoat
    Sent from my moto g(6) using Tapatalk
