Results 1 to 9 of 9
    Jan 2005
    Cordova, TN
    Default EVTM abbreviations
    Does anyone have a key to their abbreviations?
    I am wondering about T/O.
    Does anyone know what the abbreviation T/O means in the EVTM? I see it list connections and splices for example near the headlight T/O or near T/O to ground.
    qikgts's Avatar
    Jan 2010
    Rockledge, FL
    Tape out... It's a smaller harness "taped out" from the larger harness...
    '85 GT
    Jan 2005
    Cordova, TN
    Thanks! That makes sense! Any idea what the 5 digit call outs are? Like in the headlights section. It say S806 is in 14290 near T/O to ground. I have the splice in my hand, but I don't know what 14290 is. There's no connectors in this wire, except for the headlights at the end and on the pork chop brace in the car.
    qikgts's Avatar
    Jan 2010
    Rockledge, FL
    I can only speculate... Perhaps the 5 digit numbers are an engineering number or internal part number for specific harness sections or maybe connector housings themselves with I think the former to be a better guess.
    Also, remember that the EVTM(s) doesn't show the actual complete circuit, instead it's usually just a simplified representation/version of it so one can better understand and visualize the components and make-up.
    Incidentally, its been mentioned many times around here that there are many incorrect items/details in both the wiring diagram(s) and the EVTM(s) for our Foxen. I'd advise that you keep using your multimeter and don't lose sleep if something doesn't match a description.
    '85 GT
    S is splice, C is connector, G is ground. 5 digit numbers are often base part numbers, usually for wiring harnesses.
    Jim DeAngelis
    '79 Capri 2.3L n/a, Medium Copper metallic, survivor
    (bought from MRausch82)
    Jan 2005
    Cordova, TN
    Quote Originally Posted by FB71 View Post
    Now it all makes sense! That's how so many different circuits have some of the same 5 digit things in them!
    I've wondered what T/O meant for a long time. Never could come up with anything searching online. Thanks.
    Thomas
    Jan 2005
    Cordova, TN
    It's weird there's not a key or index in the EVTM that explains it. I mean they explain the wire makrings, the dots/dashes/colors, splices and connector numbers. But no mention of some of the other abbreviations or part number listings.
    I know, right? Would've been a handy bit of information. I guess the techs using the manuals were expected to know that stuff.
    Thomas
