Results 1 to 2 of 2
Thread: Rear end noise?
    Default Rear end noise?
    Finally finished my 5 lug rear disc swap, unfortunately I think the carrier bearing in the rear end I put in is bad. It makes a loud howling noise the faster the acceleration. No shops I've called will mess with doing it and I've never done a rear end before. Anyone have experience with it? Is it a difficult task to under go? I'm mechanically incline. Any tips would be great, or a place around Springfield,Ohio that does them would be great. If I can post a video is let you guys hear the noise and post your thoughts on it.
    Nov 2014
    Grand Rapids, Mi
    I’ll post a couple threads. I went through this. Not hard at all, just lots of triple checking, and double checking your triple checks.
    http://vb.foureyedpride.com/showthre...have-a-problem
    http://vb.foureyedpride.com/showthre...-tooth-contact
