Results 1 to 8 of 8
    Default 1983 Capri Tail lights
    Has anyone had to restore Capri taillights 83-86? Any advice or tips for someone who's looking to make his new again? I've seen various threads talking about polishing and sanding but they're restoring mustang taillights. I was looking to buy some cheap beat up ones on ebay to practice on with because mine aren't that faded but it looks like the clear portions are going a bit.
    Name:  IMG_20151229_164456568 - Copy.jpg
    Apr 2016
    Sprague River, OR
    I haven't restored Capri lenses, but they should be the same process as any other light. The fins will be a little harder to do.
    Join The Conversation
    I have an 81 Capri that also has the raised fins. After my car was repainted the dull taillights stuck out like a sore thumb. While the car was being wet sanded and buffed I also did the taillights. The taillights themselves turned out great but the black fins were still faded so had to paint them in the end.
    HAD
    14 Mustang GT
    94 Mustang GT
    93 Mustang LX
    HAVE
    81 Capri - 302 with 351 heads, 4 speed top loader
    68 Mustang Coupe - 351W, 5 speed tremec
    The best option IMHO and experience is to wet sand the tail light lens with 400 grit sand paper. Then mask off the clear portion of the lens. Spray the fins and non clear portions with a base coat black or charcoal grey depending on year model. 79-84 black and 85/86 charcoal grey. Then unmask and top coat with clear.
    This will give you the best look and durability. If done correctly the lights will look brand new at a minimal investment of time and $$. Good luck!
    Thanks for the great advice fellas
    I'm going to give sanding and painting a shot.
    Professional restorers do an acid dip first to remove any organic compounds.
    Never thought about putting a clear over them. This would likely be a one time restoration as it would probably difficult to remove the paint.
    No sure why you would need to remove the paint, but in my experience doing the BC paint with Urethane Clear coat over the entire lens holds up very well long term without issues. No different than any other part on the car sprayed with clear. I am sure after extreme sun exposure and/or 15-20 years of age there may be some deterioration, but still worth the time and $$ IMHO. This is how I do all of my Mustang and Capri tail lights and have had zero issues over the years. Most who see them, can't believe they aren't brand new.
    Agree sand, base with color, clear. The will look brand new and last a long time. Even a rattle can job can look good just take your time.
