Results 1 to 13 of 13
Thread: 1983 Capri RS
    New User
    Nov 2017
    Round Rock, Texas
    Default 1983 Capri RS
    Foxchasis,
    Here is the door tag and buck tag for a 1983 Capri RS I just picked up in Lubbock. Not sure what's in the Lubbock dirt, but this car has not been on the road since 1998, was covered in dirt and has zero rust! The 4 digit code in the upper right hand corner is 0315. Also, the NLR looks like it has an 8 punched in there as well?
    This car is remarkably stock/original. Dirty as heck thanks to West Texas dust/dirty, but virtually all original and unmolested overall. Needs some TLC, massaging, a fender, paint, and interior, but the bones are in great shape and awesome starting point for a rebuild/restore. Definitely in better shape than either of my latest Capri purchases.
    New User
    Nov 2017
    Round Rock, Texas
    Here are some pictures before and after a little high pressure water was applied!
Size:  112.6 KBName:  IMG_2875.jpg
Size:  112.6 KBName:  IMG_2876.jpg
Size:  129.0 KBName:  IMG_2879.jpg
    VIN
    1ME = Mercury vehicle manufactured in USA
    B = active belts, no airbags
    P = passenger car
    79 = Capri 3-dr sedan (hatchback)
    F = H.O. 5.0L V8 engine
    8 = VIN check digit
    D = 1983 model year
    F = Dearborn Assembly
    605888 = 5,888th 1983 Mercury scheduled for production at Dearborn Assembly
    Door Tag
    Date - 09/82 = September 1982 scheduled build
    GVWR - 3950 lb/1791 kg = gross vehicle weight rating
    Front GAWR - 2094 lb/949 kg = front gross axle weight rating
    Rear GAWR - 1909 lb/865 kg = rear gross axle weight rating
    F0061 = 61 lbs front accessory reserve load
    R0058 = 68 lbs rear accessory reserve load
    Exterior Paint Colors - 27 1C = Bright Red upper (27) Black lower (1C) (tu-tone paint)
    DSO - 22 = Dallas district sales office
    Body - 61D = Capri 3-dr sedan (hatchback)
    Int Trim - DD = cloth & vinyl seating, low-back front buckets (D), Medium Red interior trim color (D)
    A/C - A = factory manual air conditioner
    R - 7 = AM/FM stereo radio with cassette tape player
    S - D = T-roof
    Ax - Z = 3.08:1 axle ratio, Traction-Lok differential
    Tr - 4 = manual overdrive (Tremec 'SROD' 4-speed) transmission
    LL = front springs
    JJ = rear springs
    Buck Tag
    CAPRI = Capri model line
    TR = T-roof
    0315 = body & paint rotations #0315
    277 = Bright Red upper exterior paint color
    TT = tu-tone paint (Black lower exterior paint color)
    ST
    AC = manual air conditioner
    06 = YES rear defrost
    HB = heated backlite (rear defrost)
    S = speed control (cruise control)
    CRS = Capri RS
    WD = power side windows (W), power door locks (D)
    MOD = manual overdrive (Tremec 'SROD'4-speed) transmission
    04 = vents in hood, hole in hood covered by forward-facing non-functional hood scoop
    V = visibility (light/convenience group)
    ELECTRIC
    -D = Medium Red interior trim color
    NLR
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    New User
    Nov 2017
    Round Rock, Texas
    Thanks FoxChasis for the great info. I plan on a full restoration of this car, this will definitely help.
    How many miles on the odometer?
    Does this RS have any of the following options?
    • interval windshield wipers
    • premium sound system
    • tilt steering wheel
    The "8" punched in the tag by the NLR code is just from an assembly line worker/quality check inspection.
    If you take the interior part let me know if you find the build sheet. Thanks.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    New User
    Nov 2017
    Round Rock, Texas
    I'll check on the wipers, but it does have premium sound with the separate Amp switch and it also has a tilt wheel, with the leather wrapped steering wheel and cruise control. Where would the interior buck tag be found?
    New User
    Nov 2017
    Round Rock, Texas
    Sorry, I forgot, the odometer shows roughly 30K miles.
    Sorry, I meant to type build sheet not buck tag.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    New User
    Nov 2017
    Round Rock, Texas
    No worries. I'll be pulling the interior today and will look for that. Also, is there a way to determine what wheels came on this car? It has sway bars front and rear, so I wasn't sure if that was the "handling package" and if that meant TRX wheels were installed??
    Wheel type and wheel cover type will be on the build sheet.
    If the front and rear stabilizer bars are a specific size it would indicate TRX suspension. Both TRX and non-TRX 'Handling Suspension' included a rear stabilizer bar.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    New User
    Nov 2017
    Round Rock, Texas
    I completely disassembled the interior. No build sheet found, that must be the one thing that the Lubbock weather did effect. And I don't know that I could call the rear sway bar a "bar", clothes hangers have a larger diameter! Also, the car does have intermentant wipers.
    Thanks again for all your assistance.
    That is so NOT True!
    The rear sway bar is larger than a clothes hanger . . . At least the diameter of an E7018 welding electrode!
    I don't recalling seeing the tilt steering today, but then again you spent most of the time in the mud . . . I mean interior.
