    Default Swaybar endlinks
    How tight on the swaybar endlinks rod.? Torque spec?
    Portland Oregon
    I was taught when the bushing diameter is the same as the washer.
    67 Mustang Coupe
    96 Tangerine GT
    86 Saleen #179
    Sep 2011
    Central,Wisconsin
    If polyurethane,from MM.
    "Tighten the endlink nuts. Do not overtighten them. They only need to be snug. You should be able to rotate the endlink bushings with your fingers, but still feel some friction from the contact between the washers and the endlink bushings. If you cannot rotate the bushing, the nut is too tight. Adjusting the tightness of the endlinks with the car on the ground will ensure that there is no pre-load on your swaybar"
    Good luck
    '86 Med.Canyon Red Met.(original paint) T-top,5 speed,3.55 rear,MAF conversion(A9L).MM adj. RLCAs,T/A,Panhard Bar,and adj MMRSB-3,rear T/A springs 375#-440#,MM C/C plates,MM 1.125" dia.swaybar,STB,4pt KMB,FLSFC's,'03 Cobra rack-n-pinion w/ Saginaw pump conversion.Bilstein MM coilover conversion and A-arms,front spring rate:250#.
    Thanks. I'm sure I overdid it. I'll recheck once it's back on the ground.
    Quote Originally Posted by Tigger View Post
    That's how I do it also. Imho, *I* would rather have them a little snug, verses a little loose.
