Results 1 to 4 of 4
    Default 1986 gt front cover other misc stuff
    Cover is Oem and nice. 4 new headlights, 4 holes for front plate mount no rips, looks like original paint. Headlight panel has been ground down on drivers side but not noticeable when on car at all. $300 rather not ship.
    aluminum front bumper, looked for a long time and ended up buying another pair.
    Bought on here, have overspray on them but are certainly aluminum. $200 each, both have aluminum parking light mounts also. Will ship but cost me a small fortune to get them here so it most likely won’t be cheap depending on how far.
    sport comp tach, worked good, needs cleaned up, some rusting around metal knob retainer, $50.
    Afco radiator and flexalite fan with built in controller and radiator probe. Barely used, rad is slightly narrower and slightly taller, have top hold down for it from my 86. $300 rather not ship
    HP turbo kit, silver ceramic on hot side including housing, tial gate, Bosch blow off, garret 60mm .96a/r. Turbo has minor shaft play but has no oil in it either, did not have any issues with it, play is no more than a Borg but wanted to mention it. 3.5 down pipe dumped in front of axle. And have piece to use stock tailpipes. No air meter or injectors, nice sturdy setup and spooled hard and fast even with a stick. $2300 rather not ship
    .Name:  E9997EEE-CF8D-4C13-B6B0-E977B240FE1A.jpg
Size:  97.9 KBName:  686CD02F-E908-4309-9828-0684A68196EE.jpg
    15801 Dubois PA
    Where in Central PA?
    Official FOX-A-QUE Threads
    : 2017 | 2016 | 2015 | 2014 | 2013 | 2012 | 2011 | 2010 | 2009
    Zip and city in thread
    Please delete thread
