Page 2 of 2 FirstFirst 12
Results 26 to 43 of 43
  1. #26
    Jul 2016
    Duncannon PA
    Im going to replace the spring isolaters when I do the sprins and shocks so how does anybody feel about Energy Suspension? I'm looking at them because I am going to order some parts from Rock Auto and was just going to throw them in with the order.
    Current Mustangs
    1966 6 cylinder coupe
    1984 SVO 9W
    1985 Saleen #132
  2. #27
    I used prothane, but I would bet there isn't a nickels worth of difference between the two. Be aware, you originals are likely junk, so you will get some lift in the rear. I would guess an inch give or take. I ended up using lowering springs eventually to get the right look
  3. #28
    I have used both Prothane and Energy Suspension. Either work just fine in regards to spring isolators.
  4. #29
    Jul 2016
    Duncannon PA
    I'm sure they're junk. Thats why I am replacing them. The lift will be ok since I'm using Eibach sports springs.
    Current Mustangs
    1984 SVO 9W
    1985 Saleen #132
  5. #30
    Jul 2016
    Duncannon PA
    So I installed the new springs, shocks and insulators this afternoon. The car now sits 1-1/2 inches higher. I measured at the top of the wheel opening. I haven't driven the car yet because it's raining and plus I want to do the fronts too.
    And before anyone asks, yes I made sure the springs are oriented correctly.
    Current Mustangs
    1984 SVO 9W
    1985 Saleen #132
  6. #31
    That's about where I started. I ended up with lowering springs in the back ultimately. You should also drive around the block a couple times before you cinch the control arm bolts back down.
  7. #32
    Quote Originally Posted by dagenham View Post
    Did you loosen all of the control arm bolts when you installed the new springs? If you did loosen them, did you install the springs, lower the full weight of the car onto the suspension before tightening up the rear control arms at ride height?
    Failure to loosen the control arm bolts both front and rear when doing a spring swap will affect the final ride height after the install. I personally loosen the bolts, install the springs, then take the car around the block a couple of times to cycle the suspension as much as possible. Then I jack the car up and put it on stands (actually I have wooden crib blocks that all me to set the wheels on @ 14" above the ground) jounce the suspension a couple of times to settle again, then tighten up all the control arm bolts with the car at ride height and full weight on the suspension. Good Luck!
  8. #33
    Jul 2016
    Duncannon PA
    I did not loosen any control arm bolts.
    Current Mustangs
    1984 SVO 9W
    1985 Saleen #132
  9. #34
    Seems like you may want to loosen things up and bounce it a bit then torque stuff down
    four car ramps work great. Drive up on the front the jack up the back and put them into place.
  10. #35
    Jul 2016
    Duncannon PA
    So which bolts should be loosened? The uppers or the lowers and which end, the body end or the axle end?
    Current Mustangs
    1984 SVO 9W
    1985 Saleen #132
  11. #36
    Both ends of the upper and lower control arms is the procedure you’ll want to follow.
    Easy cruise around the block a few times then up in the air jacking off the center section of the rear diff then tires on the perch at the top of ramps is what I suggest
    torque it all down and see where things are from there.
  12. #37
    Jan 2011
    Vancouver BC Canada
    I would loosen all 8 trailing arm bolts. The rubber control arm bushings only have a certain amount of flex built into them, If you do not loosen all the mounting bolts, and lower or raise the car, the bushings are not in the middle of their flex travel, so you could potentialy cause the bushings to eventually tear, and they could also make the car sit higher (or lower, depending on where the car is sitting in relation to the starting height.) By not having the bushing in a relaxed state at ride height, the bushing has a twisting load on it, similar to how a torsion bar functions.
  13. #38
    Jul 2016
    Duncannon PA
    One more stupid question. Should I need a compressor to put the Eibach sport springs in the front? With the Energy Suspension isolators on they need to be compressedabot 2 inches to be able to go in.
    Also I'm concerned about the ride height when I'm done. The new springs are taller than the old Racecraft springs. The rears were the same height when I compared old and new.
    Current Mustangs
    1984 SVO 9W
    1985 Saleen #132
  14. #39
    YES.
  15. #40
    I’ve always just unbolted the co trial arm and used a jack when putting in lowering springs.
    Stock front springs definitely need a spring compressor.
    Ride height will depend on sprig rate and length. A lighter spring will compress more so even if it’s longer it may end up shorter with weight on it.
  16. #41
    Most of the time, I can install lowering springs without a spring compressor. Although I generally loosen the front control arms so they will drop down and literally point directly down at the ground. That gives me the most room to fit the spring and makes sure that the control arm is not preloaded before installing the new springs. I will admit that if you have the good spring compressor OTC 7045B, then not a big deal, but I never have much luck with all the other types . . . At least not on a Fox. Good Luck!
  17. #42
    Makes the job so easy... right tool for the job.
    86 SVO 2R Comp Prep
    86 SVO 9L Comp Prep
    86 SVO 7B Comp Prep
  18. #43
    Yes, big pain in the neck without the right tools
    Maximum Motorsports sells a tool that works well with lowering g springs I’m told. Without lowering springs, expect to compress the coil through the opening in the A arm and put it up into place and attach the spindle and strut. Very hazardous work, be careful!
