Results 1 to 12 of 12
    Default Ragtop power window motor
    I'm not sure if this is the right section for this question but I'm looking for some info on replacing my power window motor in my 84 GT vert. I noticed a couple of the guys are missing there felt also anyone got a fix for that or tips tricks filming in point me in the right direction thanks guys
    I would rather be juged by 12 than carried by 6
    Is your old motor present? It could be a simple repair.
    Yeah, I have had to replace the little plastic bearings in both my rears. Easy job to do actually.
    yes i have the old motor I removed it from the door last night. But I need new guides and one of the little felt pieces is missing the felt from it. All other windows work flawlessly rear quarter Windows have New Motors. Just want to know about the guides and track or anything to replace there or even where to get it
    Yeah, I could use some new felt on my rears too. If you figure it out, post it. I have never seen replacement parts for those. I got the fronts replaced though. I think lmr or cjpony had them.
    emerygt350 I'm actually working on the front front passenger
    my fronts were easy but I had to use some machine screws to put the felts in place, I just lubed the crap out of the existing rails with silicon spray.
    Top picture has the felt missing the bottom picture is what I really want
    When I worked on my rear quarter windows i needed the felt as well. I used some of the felt you can get at hobby stores that has the "sticky" on the back. Worked like a charm.
    Ahh, I thought you were talking about the dew wipe...
