Long story short my rear air shocks are shot on my 85. There's a hole in the bag of one so they won't hold air. I'd rather not run air shocks again if I don't have to. Now I know you get what you pay for but I don't have much money after doing a 347 swap. So does anyone have an idea of what gas shock I can hopefully run with 28" tall tires that don't clear the fenders because of my offset. So I need them (if possible) to hold the car enough so I'm not hitting the tires so often on bumps. I've had air shocks since I put this bigger wheel setup so I have no clue if a stock gas shock will hold the car up enough. Everything is stock, springs and control arms so the car has no way to adjust ride height. A couple people have told me to run Lakewood 50/50s but reading up on them those are shorter than stock so I don't see how those would hold the car up enough? Any help is much appreciated.
