Page 3 of 10 FirstFirst 12345 ... LastLast
Results 51 to 75 of 246
  1. #51
    So while I wait on Jegs to exchange my broken Water Temp gauge, this week I started getting prepped for my 5-lug conversion...well sort of anyway. I started to prep my 17" steel wheels for paint. https://youtu.be/ZDPgV1zDc4c
  2. #52
    It's like every time I get something fixed on the gauge pod, something else malfunctions...https://youtu.be/iNqmn8uVg5k
  3. #53
    Yeah, your odds of finding an early F/Z in a good color are NOT good.
    This is my '79 F/Z with a non-beige color. I remember that beige color back then. I don't know what we were thinking back in the '70s, but I do know that I probably had a pair of bell-bottomed pants (and platform shoes) in that exact same plaid color as what's in the interior of his Futura. ;-)
  4. #54
    Your wheel/tire combo looks spot on!
  5. #55
    Quote Originally Posted by Str8sixfan View Post
    Thanks! I've got those wheels put away for the winter and have a set of 16-inch 1995 Mustang GT standard wheels on right now.
    Name:  FairStang Driver Side.jpg
    Also, I still have those plaid front buckets and rear bench seat. The seats in there now are beige-ish/brownish vinyl. I know the Age of Plaid seats aren't going back into the interior of this FairStang because I'm going to restomod it for the most part with a mix of '86 Mustang GT and other parts inside. And also because plaid brings back too many memories of my teen years in the late 1970s. ;-)
    Name:  FairStang Original Plaid Bucket Seat.jpg
    Name:  FairStang Original Plaid Bucket Seat1.jpg
    Name:  FairStang Original Rear Seat.jpg
  6. #56
    Yea, those are exactly my seats!
    Here's the latest update on my build. Not much this week. I'd say hopefully the next 1.5 months will end up being a huge turning point for my car though, especially thanks to a member on this forum.
    https://youtu.be/p1nRiejE6cs
  7. #57
    Ashtray gauge pod is finally complete! https://youtu.be/wEbhadX6eEg
  8. #58
    I'm up for input on my venture into the 5-lug swap - https://youtu.be/Mv8aiKl3Sbg
  9. #59
    Dropped the fuel tank today! https://youtu.be/SnbDyris1XQ
  10. #60
    Jul 2009
    Chicago, south subs
    http://vb.foureyedpride.com/showthre...version-Thread
    Can I assume that you've taken a look at the above thread?
  11. #61
    Yes. Been through it several times. There's very little info on Ranger front Rotors. Luckily I was able to by-pass all of that since Erratic50 sold me his old set-up. Also if you watched the video, I mention how I had mis-read some other info from that thread (though I don't actually reference the thread itself), thinking that the axle I bought was 1.25" wider total than stock...rather it's 1.25" wider on either side.
    I hope to have it mocked up by the end of the month though.
  12. #62
    Jul 2009
    Chicago, south subs
    So you have the front set up? I put '87+ GT front spindles/calipers/rotors on mine, but I stayed 4 lug. I think all I would need for 5 lug is Mark VII rotors. This gives the larger 11" discs. I also added the GT sway bars front and rear while I was under there.
  13. #63
    I have the parts, they're not on yet. Hypothesizing that I'll need to run some spacers, but I know a good place to get some 7/32" spacers that are 5 on 4.5" if need be. Going to mock it up without first.
  14. #64
    Fuel gauge works again! https://youtu.be/h3KlLgkdM6E
  15. #65
    Going to try and pick these up today for the car! https://youtu.be/pIu6tXZyLEA
  16. #66
    Jan 2004
    Olathe, Kansas
    Looks like a good shop, I need to call them with my heads and get a quote. Thanks!
    Now stang-less.
    88 Cougar 5.0
  17. #67
    Do it, tell them I sent ya! You're now like the third one to say something similar. Heck if I send enough people their way, they might get you a discount!
  18. #68
    Check it out! I drove my Fairmont to work on Friday - https://youtu.be/2-Do3rOH7hw
  19. #69
    Jan 2004
    Olathe, Kansas
    What valve springs did you wind up installing on the heads? Thanks Grant.
    Now stang-less.
    88 Cougar 5.0
  20. #70
    Coming along! Good to see it on the road!
  21. #71
    Went with stock valve springs since I have zero intention of doing a cam swap on the budget build. I'm going to run out of money anyway. I was wanting to do some 1.7 Rockers, but I don't think that will end up being in the budget either. The way things are looking right now, is I probably end up in the 5-10% over budget range.
  22. #72
    Jan 2004
    Olathe, Kansas
    200-400 over, I still consider that a success. Keep it up.
    Now stang-less.
    88 Cougar 5.0
  23. #73
    https://youtu.be/90vGkelem4g?list=PL...bjNanCciDvnkSc
    The 8.8 rear axle swap is underway!
  24. #74
    Had a chance to mock-up the rear axle with the wheels I bought today - https://youtu.be/BVRATpKlPgg
  25. #75
    Started to address the pinion seal issue on my 8.8 I'm installing - https://youtu.be/QF1AEagcshg
