Page 4 of 4 FirstFirst ... 234
Results 76 to 88 of 88
  1. #76
    Started rebuilding the rear calipers today - https://youtu.be/J1FpfO6MZn0
  2. #77
    Finished rebuilding the rear calipers yesterday - https://youtu.be/-GMW_ETOrSU
  3. #78
    Jan 2004
    Olathe, KS
    Nice job. I tinkered with my car a bit this weekend also.
    Now stang-less.
    88 Cougar 5.0
  4. #79
    Feels good, doesn't it?
  5. #80
    Getting closer with the Mark VII rear end - https://youtu.be/7b2TIaPLQgg
  6. #81
    Jul 2009
    Chicago, south subs
    Do you have a plan for connecting the rear brake line to the axle? When I swapped the 8.8 into my car, I just disconnected the lines at the brake cylinders from the 7.5 and reconnected them on the 8.8. But I don't know if that works for the Mark VII rear(disc brakes). It wasn't a perfect fit because the center of the 8.8 is larger, but it can be made to work. I guess the 'correct' way to do it is to use the center brake line bracket (being reproduced now: https://lmr.com/item/LRS-2073BRKT/mu...-bracket-86-93), but this also requires rerouting the rear line on the chassis to get to the bracket. I have all these parts for mine, just haven't installed them yet.
  7. #82
    Jan 2004
    Olathe, KS
    Nice work. Getting there. Its been so dang humid and hot lately, nice motivation.
    Now stang-less.
    88 Cougar 5.0
  8. #83
    It was nasty out there yesterday for sure. But it was a fruitful day.
  9. #84
    I do think I will probably end up doing that LMR kit. Hoping to have everything hooked up next week to be able to evaluate that situation best. I'm a little worried about how big the line is that gets to the back of car is. Because it's smaller than the lines currently on the axle. I hope to have a friend whom I trust come over and help me evaluate that situation. Because if I have to upsize that line (that goes through the interior of the car), I might end up fabbing up some other solution in the process.
  10. #85
    Jul 2009
    Chicago, south subs
    Some people just run a new prebent line all the way from the front, it runs along the frame rail. I did this on another car. I've also seen where the existing line is bent over to where that bracket mounts. That might involve upsizing the fitting, I'm not sure. There's probably a thread in brakes section of this forum.
  11. #86
    I should probably be more ambitious than this, but that's why the priority is to get the axle and springs and what not all reinstalled in the car first. Then start to assess what my options are for the brake set-up.
    Feel like I can mentally wrap my head around all of that 1) when I'm able to sit there and physically look at where everything lands, and 2) when I don't have the other work hanging over my head as things left to do. I feel like the concentration will be better.
  12. #87
    Jul 2009
    Chicago, south subs
    Not trying to push you Grant. Work at your own pace. Just was curious is all. It's all good.
  13. #88
    Oh no...I didn't take it that way, was being more self reflective out loud! haha. I did get the driveshaft connected tonight, so maybe some other night this week I can get to the links. Didn't get the flange torqued down yet, but I put it on the list. I did blue locktite the bolts.
