Results 1 to 22 of 22
    FEP Member svo84's Avatar
    Oct 2006
    York, Pennsylvania
    Default 1980 Mustang turbo coupe Tu-Tone
    I am in the process of getting my car from the west coast. it is a 80 turbo coupe two tone. the only change done is an EFI turbo, 5spd. swap. I will be doing a Marti report soon. The owner said he could not find the buck tag. where they put in any other spots on the two tone cars? this car was a show car at one with the original owner.
    Car was built at the San Jose assembly plant and the buck tags are not in the same place at cars built at the Dearborn assembly plant. I will be down low on the core support, either behind the bumper shock bracket/bumper or slightly higher than that.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    I would be very interested in seeing the buck tag. I don't know If i have ever seen a buck tag from a special tu-tone paint car built at San Jose, so my buck tag decoder would not currently work for such until I could see a tag and make corrections.
    VIN
    0 = 1980 model year
    R = San Jose Assembly
    02 = Mustang 2-door sedan (coupe)
    A = non-turbocharged/turbocharged 2.3L engine
    146977 = 46,977th 1980 Ford scheduled for production at San Jose Assembly
    Door Tag
    Date - 04/80 = April 1980 scheduled build
    GVWR - 3800 lb/1723 kg = gross vehicle weight rating
    Front GAWR - 1985 lb/900 kg = front gross axle weight rating
    Rear GAWR - 1835 lb/832 kg = rear gross axle weight rating
    F0182 = 182 lbs front accessory reserve load
    R0079 = 79 lbs rear accessory reserve load
    Exterior Paint Colors - 3J 9D = Bright Blue upper (3J), Polar White lower (9D) (special tu-tone paint)
    DSO - 72 = San Jose district sales office
    Body - 66B = Mustang 2-door sedan (coupe)
    Int Trim - DB = cloth & vinyl seating with interior accent group, low-back front buckets (D), Wedgewood Blue interior color (B)
    A - [blank] = no factory air conditioner
    R - 7 = AM/FM stereo radio with cassette tape player
    S - B = sunroof
    Ax - F = 3.45:1 axle ratio, non-locking differential
    Tr - 6 = manual Borg Warner (RAD) 4-speed transmission
    VV = front springs
    FF = rear springs
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Apr 2009
    Denver, Colorado
    That's a fine looking coupe..
    Current rides:
    89 LX 5.0, 5 -spd..the Lemon
    86 RS Capri 5.0 Auto...
    85.5 SVO, Finally Got Boost
    FEP Power Member Fearnot's Avatar
    Concord NC
    Great looking coupe!
    88 Turbo Coupe auto
    88 Turbo Coupe 5spd
    79 Fairmont Futura 4.6
    80 Capri 5.0/5spd project
    79 Pace Car 5.0/5spd project
    86 GT conv 5.0/5spd
    Oct 2006
    York, Pennsylvania
    I will ask him to look there. Thank you
    Oct 2006
    York, Pennsylvania
    Default 1980 Turbo Coupe
    More paper work
    Oct 2006
    York, Pennsylvania
    Got the Marti report. Still dont know where owner got the 1-119 made? Going through more of the paper work from Ford.
    FEP Super Member tORMENtOR's Avatar
    Oct 2007
    Bethlehem,PA
    So glad to see you got this car Matt, its a special car. Congrats
    Oct 2006
    York, Pennsylvania
    Thanks Joe, waited awhile for this one.
    Oct 2006
    York, Pennsylvania
    Can find buck tag on support. Have to get under the car and look. Hoping I missed it.
    You'll be able to see it from below. Just above bumper/bumper shock on passenger side.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Oct 2006
    York, Pennsylvania
    Thank you
    Mar 2013
    DENVER CO, the 303
    Quote Originally Posted by svo84 View Post
    Wow!!! Love the marti. Hard to believe they made as many as they did and are hardly ever seen/found. Great looking car!!!
    Oct 2006
    York, Pennsylvania
    Thank you. I have seen two white and blue two tone notch’s non turbo one for sale in NC the other was in a bone yard on the web.
    Oct 2006
    York, Pennsylvania
    I found the buck tag. It is not going to be easy to get to. Going to have to remove header panel. Will post when I get it out.
    In the mean time would you post larger/closer pic(s) of the build sheet and owner card? Thanks. I can also decode them if you'd like.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Oct 2006
    York, Pennsylvania
    Here is the owners card and build sheet. Please decode. I am still trying to figure out how the passed owner came up with the production number of this car. He said it was 1 of 119 all of his car show documents same this. I am adding some more of the paper work given to me. Thank you again.
    VIN
    0 = 1980 model year
    02 = Mustang 2-dr sedan (coupe)
    Owner Card
    0R02A146977 = [VIN decoded above]
    A = unknown
    3J9D = Bright Blue upper exterior paint color (3F), Polar White lower exterior paint color (9D) (special tu-tone paint)
    66B = Mustang 2-dr coupe
    DB = cloth & vinyl seating, low-back front buckets (D), Wedgewood Blue interior trim color (B)
    09D = April 9th scheduled build
    F 6 7B = 3.45:1 rear axle ratio w/ non-locking differential (F), Borg Warner 4-speed manual transmission (6), AM/FM stereo radio w/ cassette (7), sunroof (B)
    Build Sheet
    Line A
    Rotations Number - 723 = trim & chassis rotations #723
    Line - Z = Mustang model line
    Serial Number - 0R02A146977 = [VIN decoded above]
    Body Type - 66B = Mustang 2-dr coupe
    Body, Tops, Roof - 7 = Sunroof
    Ext, Paint, Body - 3J = Bright Blue
    Ext, Paint, Accent - 9D = Polar White (special tu-tone paint)
    Inst BD - C = special tu-tone paint
    Ext, Tutone - DB = cloth and vinyl seating, low-back front buckets (D), Medium Wedgewood Blue interior trim color (B)
    Int, Trim, Dev - [blank] = no interior trim deviation
    Int, Trim, Dev - B = Wedgewood Blue instrument panel color
    Type of Order - 2 = dealer stock order
    Region & District - 72 = San Jose district sales office
    Line B
    Emission Control - 2 = California emissions system
    Engine - T = turbocharged 2.3L engine
    Trans - 6 = Borg Warner 4-speed transmission
    Air Cond - [blank] = no air conditioner
    Engine, Tag Number - SK171AB = California calibration (S), Thermactor emissions with or without A/C (K), 2.3L engine (171), release level AB
    Transmission, Part Number - E0ZR DA = manual transmission (R) originally engineered for 1980 (E0) Mustang (Z), release level DA
    Seats, Type - 2 = low-back bucket seating
    Belts, Type - D = deluxe seats belts
    Belts, Color - B = Wedgewood Blue seat belt color
    Line C
    Imm Block Heater - [blank] = no immersion engine block heater
    Line D
    Groups, Décor, Int - [blank] = no interior decor group
    Groups, Décor, Ext - [blank] = no exterior decor group
    Groups, Décor, Appear - [blank] = no appearance decor group
    Electrical, Wipers - [blank] = no interval windshield wipers
    Electrical, Defogger - [blank] = no electric rear window defroster
    Electrical, Clock - D = digital clock
    Electrical, Audio, Radio - R = AM/FM stereo cassette radio
    Electrical, Audio, Spkrs - Z = four speakers with premium sound system
    Electrical, Lights, Light Group - [blank] = no light group
    Power Aids, Deklid Release - [blank] = no remote decklid release
    Mouldings, Rocker - [blank] = no rocker panel mouldings
    Carpet/Mats - [blank] = no floor mats
    Console - C = console
    Mirror, Vanity - [blank] = no passenger side vanity mirror
    Mirror, Outside - B = dual remote control mirrors
    Line E
    Battery - DC = heavy duty battery (54 amp-hr)
    Driveline, Speed-O, Metric - [blank] = no metric speedometer
    Driveline, Rear Axle, Tag Number - 281D = 3.45:1 axle ratio, conventional (non-locking) differential
    Suspension, Springs, Front, Left - VIP = V front left spring code
    Suspension, Springs, Front, Right - VIP = V front right spring code
    Suspension, Springs, Rear, Left - LEG = F rear left spring code
    Suspension, Springs, Rear, Right - LEG = F rear right spring code
    Pkgs, Hndlng - [blank] = no handling suspension package
    Line F
    Wheel Area, Wheel Covers - [blank] = no wheel covers
    Wheel Area, Wheels, Code 1/2 - TX = forged aluminum TRX wheels
    Tires, Size - 19065RM = P190/65R390 radial metric tires (Michelin TRX)
    Tires, Color - [blank] = tires with black sidewall
    Tires, Spare - M = mini spare wheel/tire
    Tires, Quantity - 4 = four full size tires
    Front End, Speed Control - [blank] = no fingertip speed control
    Front End, Steering Wheel/Column, Color, Wheel Color - A = Black steering wheel color
    Front End, Steering Wheel/Column, Color, Column - A = Black steering column color
    Hood Scoop - S = hood scoop
    Frt License Plate Bracket - X = front license plate bracket
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Jun 2016
    Saint Clair MI 48079
    Very sharp FOX !
    Oct 2006
    York, Pennsylvania
    Thank you again.
    Default 80 mustang
    Do you still have turbo coupe?
    Thanks Chris
