Results 1 to 15 of 15
    FEP Supporter svo84's Avatar
    Oct 2006
    York, Pennsylvania
    Default 1980 Mustang turbo coupe Tu-Tone
    I am in the process of getting my car from the west coast. it is a 80 turbo coupe two tone. the only change done is an EFI turbo, 5spd. swap. I will be doing a Marti report soon. The owner said he could not find the buck tag. where they put in any other spots on the two tone cars? this car was a show car at one with the original owner.
    Car was built at the San Jose assembly plant and the buck tags are not in the same place at cars built at the Dearborn assembly plant. I will be down low on the core support, either behind the bumper shock bracket/bumper or slightly higher than that.
    Buck Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    I would be very interested in seeing the buck tag. I don't know If i have ever seen a buck tag from a special tu-tone paint car built at San Jose, so my buck tag decoder would not currently work for such until I could see a tag and make corrections.
    VIN
    0 = 1980 model year
    R = San Jose Assembly
    02 = Mustang 2-door sedan (coupe)
    A = non-turbocharged/turbocharged 2.3L engine
    146977 = 46,977th 1980 Ford scheduled for production at San Jose Assembly
    Door Tag
    Date - 04/80 = April 1980 scheduled build
    GVWR - 3800 lb/1723 kg = gross vehicle weight rating
    Front GAWR - 1985 lb/900 kg = front gross axle weight rating
    Rear GAWR - 1835 lb/832 kg = rear gross axle weight rating
    F0182 = 182 lbs front accessory reserve load
    R0079 = 79 lbs rear accessory reserve load
    Exterior Paint Colors - 3J 9D = Bright Blue upper (3J), Polar White lower (9D) (special tu-tone paint)
    DSO - 72 = San Jose district sales office
    Body - 66B = Mustang 2-door sedan (coupe)
    Int Trim - DB = cloth & vinyl seating with interior accent group, low-back front buckets (D), Wedgewood Blue interior color (B)
    A - [blank] = no factory air conditioner
    R - 7 = AM/FM stereo radio with cassette tape player
    S - B = sunroof
    Ax - F = 3.45:1 axle ratio, non-locking differential
    Tr - 6 = manual Borg Warner (RAD) 4-speed transmission
    VV = front springs
    FF = rear springs
    Buck Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Apr 2009
    Denver, Colorado
    That's a fine looking coupe..
    Current rides:
    89 LX 5.0, 5 -spd..the Lemon
    86 RS Capri 5.0 Auto...
    85.5 SVO, Finally Got Boost
    FEP Power Member Fearnot's Avatar
    Concord NC
    Great looking coupe!
    88 Turbo Coupe auto
    88 Turbo Coupe 5spd
    79 Fairmont Futura 4.6
    80 Capri 5.0/5spd project
    79 Pace Car 5.0/5spd project
    86 GT conv 5.0/5spd
    Oct 2006
    York, Pennsylvania
    I will ask him to look there. Thank you
    Oct 2006
    York, Pennsylvania
    Default 1980 Turbo Coupe
    More paper work
    Oct 2006
    York, Pennsylvania
    Got the Marti report. Still dont know where owner got the 1-119 made? Going through more of the paper work from Ford.
    FEP Super Member tORMENtOR's Avatar
    Oct 2007
    Bethlehem,PA
    So glad to see you got this car Matt, its a special car. Congrats
    Current Stangs+
    84Gt (9W) T-top 347EFI
    http://www.foureyedpride.com/content...984-Mustang-GT
    84Gt(1E)Hardtop Turbo
    84Gt(1C)Sunroof 306
    Oct 2006
    York, Pennsylvania
    Thanks Joe, waited awhile for this one.
    Oct 2006
    York, Pennsylvania
    Can find buck tag on support. Have to get under the car and look. Hoping I missed it.
    You'll be able to see it from below. Just above bumper/bumper shock on passenger side.
    Buck Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Oct 2006
    York, Pennsylvania
    Thank you
    FEP Supporter STANGMAN116's Avatar
    Mar 2013
    DENVER CO, the 303
    Quote Originally Posted by svo84 View Post
    Wow!!! Love the marti. Hard to believe they made as many as they did and are hardly ever seen/found. Great looking car!!!
    Oct 2006
    York, Pennsylvania
    Thank you. I have seen two white and blue two tone notch’s non turbo one for sale in NC the other was in a bone yard on the web.
