Results 1 to 3 of 3
    Default 1990 Mustang 5 speed swap into 1986 Capri
    I am looking to swap out my automatic to a 5 speed and there is a donor 1990 available with a factory 5 speed. Are there any fitment issues? Can I use the pedal assembly from the Mustang in my Capri? Both cars are stock 5.0s.
    Mar 2003
    Lowell, Oregon
    Yes, the items will fit and the transmission also. But I am not sure about the speedo cable. You are getting all the parts- block plate, bell, trans...? Might also need the cross member.
    Apr 2008
    Waikoloa , Hawaii
    Only thing that won't be exact is the transmission harness. Different type of connectors from 87 up. If you stick with your factory automatic harness, it will require a jumper to bypass the neutral safety switch.
    1986 CHP SSP Coupe
