Results 1 to 13 of 13
    Default Error 406 - Not Acceptable - Help
    "Error 406 - Not Acceptable
    An error has occurred. Generally a 406 error is caused because a request has been blocked by Mod Security. If you believe that your request has been blocked by mistake please contact the web site owner."
    I get the above message, on a blank white page, specifically when trying to go to 85MUSTANGTGT's "Thomas' 1985 GT Build" on the Online Car Show/Show & Tell board. I noticed this some time ago when Thomas began his thread, but hadn't time at the time to ask about the issue. Is it the apostrophe in the thread title? There are 15 replies and 1101 views right now, so some must be able to access the thread... ? I don't know, I can't get to it to see, lol... please advise...
    1983 Mercury Cougar 3.8L LS
    1981 Mercury Marquis Brougham
    1971 Mustang Fastback
    1974 Pontiac Luxury LeMans
    I've been getting a different error message when I try to use the site search function.
    FEP Member Dave9052's Avatar
    Jun 2016
    Saint Clair MI 48079
    I get the same Error 406, as Walking-Tall
    I'm not sure what's going on with my thread. I can view the thread just fine, but I do get an error when I post to my thread. The post still goes through just fine, however, and I am able to view it after navigating back to the forum main page. I assume the apostrophe must have something to do with it. I'm not sure how to remove it though, the Mods may need to do that.
    I notice that there are several threads with apostrophes in the title that don't seem to have issues, including yours Mike.
    Thomas
    347 (10.5CR, AFR 185's, PP Crosswind, Comp Custom Cam, Holley SA "670"), T-5, 8.8 w/3.55's, MM SFC's, T/A, PHB, LCA's, STB, KMB, Bilsteins, MM/H&R Springs, SN95 5-Lug, Cobra Brakes, '04 Mach 1 Steering Rack
    I checked some of the other threads that have apostrophes in the titles and when you hover over them to show the link address the apostrophes do not appear. On my thread the apostrophe DOES show up in the link address, so I'm assuming that is the problem.
    Can the Mods fix the link to my build thread, please?
    Thomas
    1985 GT owned since new
    Thanks. That's true, but I'm sure not everyone knows to do that.
    Thomas
    Thread fixed. Do not use special characters in thread titles.
    Thank you, Foxchassis. I didn't realize it was an issue when I made the thread.
    Thomas
    Nor did I. Thank you.
    I’m getting this same error message on the classified add I posted today ?
    Apr 2010
    Portland, Oregon
    ...Do not use special characters in thread titles.
    80ís mustang front floor mats
    As FoxChassis said.
    May 2014
    Hudson CO
    A couple weeks ago I got that just trying to see the new posts. did it for 2 days then ok.
