Results 1 to 9 of 9
    Default Why are there floor pan plugs?
    After restoring my '82 and seeing rust that accumulated around the rubber plugs, it begs the question, "Why even have them?"
    The fit seems so tight that it doesn't look like water would really drain from them. Then, it just creates another crevice for rust to form. Would it be better to just weld over that area when I replace the current rust?
    I'm sure there's logic behind it, but looking at my rusted pan, it's not that clear to me.
    This is just a guess, but I always assumed the holes where used to like up panels on the machines during building / assembly of the unibody. I see no harm in welding over them, but I see no harm in leaving them be either. If they have a little rust I would clean and paint around them with POR-15. Other than that, weld away!
    I thought they were for popping out when your car gets water in it.
    St. Louis, MO.
    My guess is those plugs were originally there to allow spot welders access to areas they wouldn't be able to get to and to provide an area for the factory sealant to drip out of the car after they dipped it.
    Scotty
    Past Pony's.....
    Apr 2008
    Waikoloa , Hawaii
    Same reason you have all those holes on the inner fenders and firewalls.. Assembly..
    1986 CHP SSP Coupe
    Here is a pic from DAP showing a conveyor fixture pin sticking up out of a floorpan hole:
    Name:  floor pans 3-dearborn-assmebly-plant-floor-pans.jpg
    Intersting. Ok, thanks everyone. Sounds like there is no reason why I wouldn't want to just weld over a hole or two if the area has rust.
    Feb 2006
    Allentown, PA
    Interesting picture... thanks for sharing!
    Your welcome.
    As drain holes, more suited for uncarpeted jeeps.
    If they pop out under carpet and pad, no way to know unless checked.
    Let water and dirt in to ruin things, especially after many years.
