I found a strange problem on my 85 SC convertible today. I've had the car up on jack stands since December while do a brake replacement convert it to true dual exhaust and swap the 7.5 rear end with an 8.8. I put the jack stands on the outer frame in front of the rear wheels and in front of the doors.
I opened the drivers side door to get in and replace a non asc steering wheel with the 3 spoke ASC steering wheel. When I got out of the car and tried to close the door it wouldn't latch. I looked at it closely and the rear of the door is sitting about 3/4ths of an inch high and is not hitting the the catch properly blocking it from closing. Is it possible I am supporting it improperly causing body alignment issues?
