What should I get for readings at every sensor? This is a 3.8 Essex CFI with the carburator style set up two injectors above the butterfly valve.
Specifically what should the ECT readings be, The ACT, IAT and 1 wire temp sending unit read?
Thank you for your time.
Sent from my Alcatel_5044C using Tapatalk
