Hey, good morning.
Last night I replaced the radiator to the mustang as it was stock. The cars "NORMAL" gauge reads at A or about 3/4 majority of the time.
I have replaced the Temp Sender, thermostat, ECT flushed coolant nothing seems to be working. The gauge didn't work till I replaced the Temp Sender. It's definitely running hot you can hear it.
What do I look for? Also I'm pulling codes H02S system lean bank 1, EVP sensor below min voltage (they bypassed the smog pump. ECT above max voltage and ACT/IAT/VAT circuit above max voltage.
I also think it's either a electrical issue, the water pump is failing or I don't even want to guess anymore. Hit me with some knowledge
Sent from my Alcatel_5044C using Tapatalk
