Page 1 of 3 123 LastLast
Results 1 to 25 of 73
Thread: Black Sunshine
    Default Black Sunshine
    New K
    Love the song black sunshine......
    and 400HP Mustangs that handle too
    La sexsorsisto! That was a goto back in the day
    The new Black Sunshine has 550hp.
    Default Sweetin' the ride
    Brake cooling ducts are in. Removed the fog lights.
    Sway bar, starter, steering shaft
    C/C plates, PS cooler and FCA's are in.
    Looking great! What all are your plans?
    [QUOTE=ZephyrEFI;1887791]Looking great! What all are your plans?[/QUOTE
    I'm building and OTD fun car!
    NRC brackets.
    Axles, rear brakes
    Mach 1 chin spoiler install. Also, painted rear calipers to match front.
    Finished install of calipers, Cobra anti-moans, 3 braided lines/brackets, new copper/nickel hard lines
    Mocked up the cooling ducts. Pretty sure the hose is too short, lol!
    Brake duct
    New wheels w/255/40/17 NT01's
    I like what your doing with your car. Looks great. Can you post some overall pics of the car if you haven't somewhere already?
    Where did you source the brake duct parts?
    Thomas
    347 (10.5CR, AFR 185's, PP Crosswind Intake, Custom-ground Comp Hyd Roller Cam, Scorpion 1.6 Roller Rockers, Holley 3310-4), T-5, 8.8 w/3.55's, MM SFC's, T/A, PHB, LCA's, STB, KMB, Bilsteins, MM/H&R Springs, SN95 5-Lug, Cobra Brakes, '04 Mach 1 Steering Rack
    Nice! Good stuff!
    Kenny Brown backing plates, Both 3" 2-ply black hose and 9x4 offset ducts from Summit.
    Power steering mod
    FEP Senior Member flyin5-o's Avatar
    Sep 2006
    Fond du Lac,Wisconsin
    Lookin' Good!
    New brake system is done, stoptech 13" up front, NRC rear cobra setup, MM stainless lines throughout, 15/16" new MC. New proportioning valve and MM's plug for the original valve. New headlines on the rear axle and replaced the one above the diff, suspect it was leaking. Learned how to flare lines and was that frustrating!! All new Maximum Motorsports k-member and front coilover suspension. MM2 dampers with 425lb springs. That is phase 1 of my master plan.
    Phase 2 is the rear suspension(torque arm PHB etc. and phase three will be the interior(seats, harnesses and I picked up an autopower 6-point bolt-in cage.
    Very nice. Always been curious how much better those 4-piston calipers are compared to the Cobra calipers.
    Thomas
    I believe the benefit is more in the thicker rotors. 1.25" vs 1" for better cooling.
    Spirit in Black
