Results 1 to 14 of 14
    Default In search of wheels
    Currently searching through looking for FR500 wheels that will fit with my 1986 Notchback. Any thoughts?
    i guess i should mention that there was a brake and rear end conversion so it has the 5 lug and a whole 04 Cobra rear end
    Ray
    1986 Mustang "Frankenstang" '03 IRS 3.8 CFI
    1997 Crown Victoria, partially Grand Marquis
    I have the FR500 wheels on my 84 and love them. Had to switch my front spindles and brakes to a 1994 mustang. I am running the 17x9 on the front with the 18x10 on the rear.
    Bob
    1967 mustang coupe -sold
    1967 cougar GT - sold
    1984 Mustang L 5.0L - Totaled
    1984 Mustang GT 5.0L
    2007 Mustang GT convertible ( wifes car)
    1997 F-350 powerstroke
    USMC Retired 1981-2001
    supercharged347, What are your tire sizes and are you at stock ride height?
    - CA car, 5.0 w/5 speed
    Mar 2013
    Where the Navy sends me...
    Quote Originally Posted by 86frankenstang View Post
    In that case you're going to need the deepest backspacing / highest positive offset you can find, as that's a wiiide rear end (as I'm sure you know).
    May 2003
    Roseburg Oregon
    And I doubt that american mucus or LMR sell something that will fit .
    The bright side is that 2005 wheel has more options .
    Jun 2013
    San Diego, Ca.
    conmech - aka Marshall
    May 2003
    Roseburg Oregon
    Will not fit his fox with an irs .
    Actually states the center cap won't fit with an irs either .
    I run 17x9 Cobra R's on all four corners of my 79 PC. I have Fox length front control arms with 94/95 spindles up front and an 03/04 Cobra IRS out back.
    The offsets I use are 24mm up front and 36mm in the rear. Front I have no real issues except the occasional rub with the wheels turned to lock going up or down a drive way/incline. The 36mm offset in the rear gives plenty of clearance to the inside, but I am very tight to the wheel lips even after being rolled over. I personally would prefer @ 40mm offset to give me just a bit more clearance to the outside. I am not 100% sure if a 10" wheel will fit with the IRS in a Fox. I seriously doubt you can make it fit with the stock style rear IRS cradle mount in place. If that were removed and a solid mount installed there may be enough clearance to fit a 10" wheel with the right offset. Good Luck!
    yeah that rear end is wide as hell. Just starting my research now instead of looking last minute
    Ray
    Ray
    May 2003
    Roseburg Oregon
    I did the IRS swap , and yes it is wider than stock .
    But it is not without its gains .
    Wheel selection is time consuming , but if you are going for function as apposed to some particular stance , cost for custom wheels is not too expensive.
    Yes you will need to step into a specialty wheel , the McWheel found in most places , will not have the look , nor the specs you need .
    Quote Originally Posted by banzaibullitt View Post
    Front tires are 235/45zr17 rear tires are 285/35zr18 and I am running the SR lowering springs at 1.5" drop all the way around and as Trey stated I only get a slight rub when turning hard. I bought them from american muscle but had to switch the front tires from my old rims as they mounted a tire way to large for the foxbody.
    May 2003
    Roseburg Oregon
    Supercharged 347 , do you have an IRS in your car ?
    If not , none of this really applies for the op.
    Nice car tho .
