I got this car from a buddy of mine. It's in great shape and runs good, but he remove the smog pump, and a lot of the vacuum lines and disconnected the AC compressor.
I plugged it back in and filled it with 134a and it blows COLD.....on the windshield.
I've done a lot of research and the line coming from the vacuum T is good, the line going through the firewall is good, but the line that went to the vacuum tank goes into the between the fender wheel , right by the battery, I haven't found the end of it yet, but it's definitely not in the non existent Vacuum tank.
The good news is, he's kept everything he pulled off, so my question is, what vacuum lines do I need to hook up to make the AC vents work?
Will bolting the vacuum tank and hooking that 1 line back up work?
