Let's see if any of you have had this same problem occur.....
Car is a 1984 GT Vert. Stock wiring harness
Been trying to get A/C going.....system was converted to 134A years ago.
I put in all new A/C components (Compressor, Condenser, Evaporator, etc.) here recently
Went to jump low pressure switch plug with A/C switch on dash turned on and compressor did nothing. I found the WOT switch plug and installed jumper wire then the clutch kicked on. When I went to take jumper out of low pressure switch plug the compressor kept running. Turned off A/C switch on dash and the compressor still kept running! It would not shut off unless I pulled jumper out of WOT switch.
Has anyone ever encountered this? Or have any insight as to what could be going on?
