New User
79 5.0 camshaft question
Hello, im new to the Mustang world and im looking at cam shafts, but my question was is the cam a hydraulic roller? My understanding is its not but wanted to double check.
New User
The block was fitted with revised, taller lifter bosses to accept roller lifters, and a steel camshaft in 1985
https://en.wikipedia.org/wiki/Ford_Windsor_engine
Short answer no
Long answer assuming the block is 79 not unless someone put a roller cam in the block, and used retrofit roller lifters
New User
Thaks guys! I just wanted to double check.
- You may not post replies
- You may not edit your posts
Forum Rules
