I have had this issue for awhile. When I accelerate the AC stops blowing out the front vents and blows out the defroster for a few seconds, then goes back to the front vents after I level off my acceleration.
I found this video on U-Tube but this guy has the same issue with an E350. He said he had to change a check valve and a AC reservoir. Cant be the same procedure for a E350 and a 84 LX. Although both Fords the setup has to be way different.
Can anyone tell me how to fix this AC problem? What part is failing or not functioning correct?
heres the E350 vid
