Results 1 to 5 of 5
    Default What is this roller block from ?
    I stumbled upon a 5.0 roller block that's supposed to be from a 90 mustang.
    Its an E7 block casting on the lower rear. Its hard to tell any other numbers in that area as the casting is kinda garbled. The partial VIN number stamped at the back of the block by the intake is "KF225820".
    Is it possible to tell from that number what it was ?
    Pull the intake. If it has the xxx or yyy stamp, its a roller block.
    Also, check the firing order of the cam. Only h.o. motors had the 351 firing order, all standard output motors (which we also rollers starting around 85, all 6 of my 86 s.o. motors are rollers) had the older 302 "non h.o." firing order.
    Block and bottom end only from a rebuild project gone wrong (spun rod bearing) that I'm looking at.
    Its definitely a roller block with the higher lifter bosses and bolt holes for the spider. Mainly I am just curious of what make/model it come out of etc.
    1989 Ford Mustang GT
    1FABP42E7KF225820
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    Perfect thanks !!
