Results 1 to 13 of 13
    New User Nice86GT's Avatar
    Dec 2010
    Toronto,Ontario,Canada
    Default 1979 Mustang Clutch Pedal Spring
    Was wonder if someone with more experience could help me out.
    Just in the process of Converting my 1979 Coupe from V6/Auto to
    5L/T5.Installed the Pedals tonight,the correct early style pedals.
    Was looking threw a Ford Parts Illustration and it shows that Ford
    Used a return spring on the the Lever where the Clutch Cable
    Connects.Anyone have a picture or experience with this?
    Dec 2011
    stanton,alabama
    Quote Originally Posted by Nice86GT View Post
    I can send you a picture tomorrow if I can text it tomorrow
    Dec 2010
    Yes that Spring with Ford basic number of 7523.
    Where do I get one?
    Default another try to find me part?
    Being a former auto parts counter person, am always interested staying in practice finding parts.
    Another part with no history or part listing easily found.
    Nothing.
    Someone on FEP has to know more.
    Early and late years no problem.
    https://www.google.com/search?client...TaT4sI#imgrc=_
    Looks similar to early Ford clutch springs with a different bend at the cable end.
    Could get an older version and bend the cable? end correctly?
    Hooks to bracket on one end and over clutch cable? at the other.
    Would it not bind the cable if attached directly to it?
    Hooks to pedal arm?
    Some clutch mfg say to remove it.
    Appears only Mustang v8 had one. Many other cars with non-cable clutch linkages did. My 2.3T no.
    Ford pickups had one a little shorter or longer.
    https://www.macsautoparts.com/ford_t...-1-8-long.html
    http://dennis-carpenter.com/clutch-p...ng/p/7RT-7523/
    From the looks of it and what i read, it assists clutching making heavier v8 clutch pedal easier to push.
    If that's the case, a hd hardware store spring could be made to work temp. Car version looks HD.
    Also looks similar to accel return springs for carb linkage on older cars. Or drum brake shoe spring.
    Run without it or experiment till we find one from salvage yard to measure or use.
    Guess its all about clutch feel and how light or heavy a driver likes the pedal to feel like.
    Newest Mustangs have one that looks like a valve spring.
    Dec 2010
    From where it is located I can only see being used to fully return the Pedal/Cable/Release Fork.I have never removed
    A Factory set of Pedals out of an early Car.Thank You for trying to help out!
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    My 73 to 79 parts book (1988 final version) says E0BZ 7523-A for all engines. They are calling it a "spring (clutch release lever rod retracting)"
    Also fits 79 Fairmont. That's it. Likely one year only.
    I'm sure you can find on original and then get some industrial suppliers to search knowing length and relative tension.
    What year(s) clutch pedal assembly do I need for a 79 Zephyr when converting from an automatic trans to a manual?
    Jul 2007
    Richmond, ME
    Any Fox manual car 78-93 except the hydraulic clutch T'birds. Ideally, the car you got the transmission from.
    94-04 can be made to fit but it requires some modification and changing to the SN95 booster; it's not worth the trouble in most cases.
    Dec 2009
    St. louis MO
    Quote Originally Posted by Ratchet1 View Post
    on my 79 mustang original C4 car we tried installing a 79-81 pedal box and it wouldn't fit. I grabbed a 82-93 pedal box and it fit perfect. I still don't understand why though.
    Keith formerly STLPONDS
    '79 V8 coupe in the works!
    Dec 2009
    St. louis MO
    Quote Originally Posted by Greywolf View Post
    What year T birds came with a manual trans?
    Thank you so much.
    Quote Originally Posted by STL79Coupe View Post
    83-88 in tbirds and 83-86 in cougar, xr7 / turbo coupe only. The 87-88 cars were the ones with hydraulic.
