Looking for advice on a recent car I acquired. I live in an area where temps are 90 - 100 during summer. I picked up an 86 Saleen that has a 331 crate motor. Radiator appears to be the original stock one. Coolant level is good, radiator looks to be in good shape.
Issue is this: On a hot day I ran it up the freeway to see how it handled the weather. Seemed fine, gauge sat in the middle, slightly above middle at times. When I took an exit and stopped at the light, gauge jumped way to the right while sitting there idling, almost pegged. Got back on the freeway to head home and went right back to normal. So it is fine with a good airflow, but idling on a hot day is not good. I fear that if I got stuck in traffic I would be screwed.
It has A/C, although it isn't currently operational. Once it is fixed I plan to drive more on hot days, but that would cause additional heating so I want to address this first.
I am wondering, is this a result of the high performance motor? Is there an upgrade to these cooling systems that would make a difference, i.e. aluminum radiator, different fan, etc.,? Has anyone else run into a similar issue?
