Results 1 to 3 of 3
    Default Emissions Valve??
    Name:  Screen Shot 2018-07-21 at 9.42.09 AM.png
Size:  589.4 KBHi all.
    i have a 1985 3.8 CFI and I went to go and remove the battery today and figured I’d also replace the battery terminal cables because they looked alittle weathered. As I was doing so, I applied too much pressure on one of the hoses from the PCV valve. I then heard a small snap noise and noticed I cracked a a valve that looks like a PCV valve but the lower body isn’t metal. It’s plastic. It was plugged into what looks like a canister under the battery. Does anyone know what this part is called? I will try to fix it with some epoxy weld if I can’t source the part. Appreciate the help! Apologies if this is in the wrong section.
    Probably from the charcoal canister. Look for fuel evaporator emissions system parts lists.
    Quote Originally Posted by JacksAO View Post
    Indeed it is! I discovered that later after posting, I ended up using some epoxy to fix the little sleeves that broke until I find a replacement
    Thank you for replying!
