Results 1 to 7 of 7
    Default Small collar on pushrod?
    The bottom push-rod came off a 5.0 with Edelbrock Perrofmer cylinder heads with SVO 1.60 rockers...
    The top came off of an engine with cast-iron GT40 heads with Crane rockers.
    Has anyone seen push-rods with collars, like the top one? Collars are stamped "UP".
    They are both the exact same length and being that I can find 8 off the "collared" ones but only 7 of the other... I was planning on using the collared ones witht the Edelbrock heads and SVO 1.60 rockers.
    Forgive my ignorance. This is all new ground for me and I don't want tto screw anything up.Name:  image1.jpg
    May 2003
    Roseburg Oregon
    Use the 8 collared ones , just so everything matches .
    I have edelbrock heads , and do not have those collars .
    I also have guide plates, so the collar would be in the way .
    I've taken apart a bunch of SBF's and never seen a collar on a pushrod like that.
    Jess
    Previously owned;
    Go with new one piece rods to be safe
    Banned
    Feb 2017
    Birmingham AL
    When I rebuilt my 85 a couple months ago, my push-rods had the collar too. I have a 98 exploder engine that does not. I inspected the ends to make sure the oil passages were clear and the holes were not wallerd out etc. and put them back in. So far no issues.
    Okay, I give up.
    Google didn't help at all.
    What's the reason/use for a pushrod collar?
    Other than saying "Gangster" on your motorcycle's exposed pushrod?
    https://gangster-choppers.myshopify....lars-with-flat
    TIA!
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    Quote Originally Posted by stangPlus2Birds View Post
    I'd say Google helped. It gave me a laugh. Amazing what might come up in a search
