Results 1 to 6 of 6
    FEP Power Member racerxmd's Avatar
    Sep 2007
    Rockville,MD.
    Default Hard Brake Line Routing in my '85GT?
    Wanting to do a complete replacement of all the hard lines on my car. Did '85 GT front to back line go through the interior under the rear seat? Or can I just a different yr. kit? I have after market Wilwood from and ready brakes to install , plus Wilwood's M/C. Pics are welcome if you have some to share.
    I replumbed my 85 Capri a few years ago (project still on-going.....). My original lines were run under the car, along the subframe on the drivers side.... If I remember correctly, I pretty much followed the same path with the new lines. I hand bent all my lines, did not use a kit....
    1985 Capri
    347 (Baker Engineering built, Dart block, GT40x, RPM air-gap, Mahle pistons, custom cam...)
    5 speed RS
    Ext - Red/Grey
    Int - Tan
    Feb 2009
    Snohomish, Wa
    85 brake lines run under the car. My 81 Capri has the line running inside the car.
    Dave
    1983 Capri RS Turbo
    1981 Black Magic 400 c6
    93 F-250 351 5sp 4x4
    Sep 2007
    Rockville,MD.
    Not sure, but I could of swore my brake or was it my fuel line ran through the interior passenger compartment by the rocker panel and underneath the rear seat.
    Quote Originally Posted by racerxmd View Post
    God I hope it's not the fuel line!
    The early cars had the rear brake line run thru the interior compartment. I forget what year that changed, but none of the fuel lines ever ran thru the interior that I have seen.
