Plucked this poor Fox out of the Maryland mud this past weekend. Very original and complete, heck the top still works. Hasn't run in 5 years, SROD was in the swampy trunk. Clean title, door sticker not so good.
79 Capri RS 5.0/AOD | 82 CHP SSP #0513 5.0/SROD | 82 Capri Tu-Tone 4.2/C5 | 83 NCSHP SSP 5.0/SROD
84 FHP SSP 5.0/T5 | 84 LTD Wagon 3.8/AOD | 85 LTD LX 5.0/AOD | 88 GT 5.0 Turbo/T5
VIN
1FA = Ford vehicle manufactured in USA by Ford Motor Company
B = active belts, no airbags
P = passenger car
27 = Mustang 2-dr convertible
F = H.O. 5.0L V8 engine
X = VIN check digit
D = 1983 model year
F = Dearborn Assembly
119807 = 19,807th 1983 Ford scheduled for production at Dearborn Assembly
Door Tag
Date - 11/82 = November 1982 build
GVWR - 3950 lb/1791 kg = gross vehicle weight rating
Front GAWR - 2104 lb/954 kg = front gross axle weight rating
Rear GAWR - 1905 lb/864 kg = rear gross axle weight rating
F__35 = __35 lbs front accessory reserve load
R___8 = ___8 lbs rear accessory reserve load
Body - 66B = Mustang 2-dr convertible
VR - W = White convertible top color
Int Trim - CN = vinyl seating, low-back front buckets (C), Opal and Medium Red interior trim color (N)
A/C - A = manual air conditioner
R - ?
Ax - Z = 3.08 axle ratio, Traction-Lok differential
Tr - 4 = manual overdrive transmission (Tremec 4-speed 'SROD')
LL = front springs
JJ = rear springs
Buck Tag
MUSTANG = Mustang model line
CVT = Mustang 2-dr convertible
277 = Bright Red exterior paint color
WHI = White convertible top color
DF
ST
PS
AC = manual air conditioner
01 = NO rear defrost
S = speed control (cruise control)
RM = rocker molding
WD = power side windows (W), power door locks (D)
MOD = manual overdrive transmission (Tremec 4-speed 'SROD')
01 = no hood scoop
V = visibility (light group)
ELECTRIC
-N = Opal and Medium Red interior trim color
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
Transmission Tag Decoder
VIN Decoder
Wow... that was fast! Thanks FoxChassis!
Cool car. Those wheels are sweet. Rarely seen anymore.
