302 with msd 6a and ready to run distributor and coil.
Quit after 8000miles. No spark. Found distributor bad as 1.5M ohms at pickup should be 850. Replaced with chinese duraspark2. Still not firing. We have 3 days of testing and still not running. Have two positive readings at the coil...
What should thr readings be at the coil when cranking?
Positive and pluse on the ground of voltage or ground?
Hard to find info on this.. need to get it running to drive him 7000miles home.
