Results 1 to 7 of 7
Thread: 86 A/C Enigma
    Default 86 A/C Enigma
    So I read many threads and thought I found the issue. Apparently not. Forum User Error I am sure ;-)
    My A/C compressor does not engage. I pulled the A/C Cutoff Switch/Relay and jumped the red power wire to the black/green compressor wire and the compressor engaged. Problem identified! (or so I thought). Replaced the relay with a new one, compressor still won't engage.
    Did I chase the wrong part? Or did I get a rare "bum" one from the supplier?
    Any advice greatly appreciated.
    May 2003
    Roseburg Oregon
    Are you sure the system has a full charge ?
    Good question. I was told when I bought it that it had been charged, but that it needed a switch. So that was the reason I acted on the cutoff switch. Now that I look into this further perhaps he meant the low-pressure switch? Not sure that is a DIY item if it is possibly under pressure? Can it be tested somehow, or is that a shop item?
    Thanks for replying, appreciate it
    Sep 2008
    HILLBILLY HOLLYWOOD, Tennesse
    Low pressure switch on the accumulator screws on and off easily for replacement with the system under pressure.
    FIRST thing you need to do is to confirm that the system is STILL properly/fully charged and NOT leaking.
    Based upon your comments from the seller you are taking their word that the system was charged properly and still is charged properly. IF you find the system is low on Freon "I" suggest you open the system, replace the accumulator, orifice tube and all 10-12 system rubber O rings and then recharge the system.
    Low system gas pressure = LEAK!
    www.musclecardeals.com
    Quote Originally Posted by vintageracer View Post
    Since you have some info that it was maybe ok, You can jumper the switch to see if that engages the compressor. Don’t run it long. There are 2 types of switches. One for R12 and one for R134.
    88 Mclaren Mustang Vert 20K miles, 89 Mustang LX Sport Vert, 92 GT Vert.
    03 Mach 1 7900 miles, 69 Mustang, 67 Mustang, 14 Mustang CS/GT,
    Thanks Vintageracer and Kevin, appreciate the info. I will check that out and go from there.
    I had a similar issue with mine. you might check the wire that supplies power to the low pressure switch. On mine it never did. I traced it back to the switch in the dash and found the wire between the A/c switch in the dash and the low pressure switch was broken. So I spliced in a new wire from switch in dash to low pressure switch. works great.
    When you have kids, you will find yourself saying things you'd never thought would ever need to be said. Ever. The other thing you will notice, is how often you will say them.....
