Results 1 to 7 of 7
    Mar 2003
    Lowell, Oregon
    Default Bell housing the same for SROD and T5?
    Seems like the bell is the same for both if memory serves. Am I correct or wrong once again?
    Mar 2003
    Lowell, Oregon
    Never mind. Searched and found my answer. So embarrassed.
    Since I am going T5 looks like I will add the SROD bell to my for sale ad.
    qikgts's Avatar
    The SROD bell is what is needed to install a Tremec 3550 and possibly others. Don't sell it for peanuts!
    Isn't the 2.3 bellhousing different from the SBF though?
    '97 Thunderbird
    Apr 2008
    Waikoloa , Hawaii
    SROD fits T3550, TKO500, TKO600.. T5 is specific, fox and SN95 are different depths on the T5 bells.
    1986 CHP SSP Coupe
    Apr 2010
    Portland, Oregon
    Yes. Adapter to use 5.0 bell on a 2.3: http://www.cididit.com/adaptor_plate.htm
    FWIW I used an MDL adapter plate on an SROD bell with a T5 tranny from a 98 V6 mustang on my son's 80 cobra when I converted from a C4.
    The extra thickness of the plate made up for the extra length of the input shaft. It does puts everything (shifter, mount) about 3/4" further back in the tunnel though so driveshaft length and/or crossmember mounting may be an issue depending. I had to trim the shifter hole and mod the boots a little bit but it all fit OK and puts the shifter in a good spot as far as I'm concerned.
    In my case I already had an SROD bell and found decent junkyard V6 T5. I had to shorten the longer C4 driveshaft on the conversion regardless so it made more sense to go that way for me.
    I'm not sure if this is the most economical or easiest way depending on what parts you already have etc.
