Most likely reasons for failure ? Was working fine today and I parked the car for 15 minutes or so - now tach doesn't work. C5 auto trans. Checked for obvious loose wires around the coil. Thanks for any help.
Check the fuse for it. If its blown you probably have a problem elsewhere like a bare or broken wire.
Bare wires - blown fuse. Thanks for looking.
