Alright, here goes:
For the past fifteen months I've been under the hood of the 86 GT fixing various things like coolant leaks, oil leaks, and overheating issues. I replaced all major gaskets and that solved the leak problem. I broke a water pump bolt and had to drill it out. Drilled into the block and coolant flowed out. Plugged the hole with high temp red sealant and permanently installed a threaded stud so as to attach the water pump. Ok there.
Flushed the cooling system with a home made pumping kit- did the radiator also. Car still runs hot but doesn't lose coolant. Car does not overheat but the gauge reads to the high side more than not.
Engine still runs hot. After only four or five minutes when the thermostat opens the underhood temp is unbelievable. Too hot if you ask me.
I replaced the distributor as I felt the high heat may have fried the PIP. I had to reset the oil pump drive shaft to reinstall the diz. It came out of the pump when I removed the diz. I relocated the TFI module to the passenger fender. That project actually went well.
I replaced the air diverter valve and the one way metal check valve that route air to the heads. I replaced the tube also. It is properly secured and clean. I used a mirror to examine the passages on the cylinder heads. They have a light coating of carbon only.
Car ran lean according to the computer. This was a grounding issues as two ground wires were missing. I replaced the main ground strap at the rear of the drivers side of the engine and the ground wire from the two ten pin connectors that grounds to the fire wall. No more lean codes. But then I had 44/94. Thought the new diverter and one way valve would take care of that.
I haven't ran the thing enough to get codes lately. Still too hot for me. And now I have SMOKE from the oil dipstick tube. First for me and I'd say very serious. Last summer the car passed both KOEO and KOER self tests and the compression test.
I trimmed about a half inch off the factory PCV hose and made sure it was on the PCV valve when I reinstalled the upper intake. Hose was cracking a little. It won't go on any further. I pulled the dipstick out and it wiped oil and looked like most of the oil was still in the engine. Can't say I smelled coolant or fuel.
Car has NO throttle response but a decent idle. The throttle cable is routed behind the intake and has some tight curves but doesn't appear that it can be routed any other way.
All vacuum lines are on correct and double checked. It sounds good at idle but I refuse to drive it anywhere.
I've put maybe ten miles on the car in fifteen months and it appears I am no better off than before.
What might the problem be? What should I expect? I would guess at this point I'll be yanking the engine next. It has 40,000 on the rebuild which was about 18 years ago.
Thanks FEP.
Cheers.
