Results 1 to 7 of 7
    Default TFI and the starter
    Strangest behavior today... I had my PIP go (code 14) so I replaced the distributor. After ordering 3 distributors with "cast" gears and getting forged on each of them... Argh. Anyway, got it all together, drove it one day and this morning the starter would engage in the "on" key position, and of course wouldn't stop till I turned the key to "off". Unplugged the tfi and the starter would operate like normal (but not start of course). Replaced the tfi module, works like it should. Crazy.
    And this doesn't help either. No electrical power at all this morning.Name:  IMG_20180701_090411.jpg
    Jul 2016
    Duncannon PA
    Sounds like coincidence I think.
    Oct 2017
    south-central WY
    If that was my car, I'd be looking real carefully at the ignition switch, especially if it was original equipment. Talking about the one at the bottom of the steering column.
    Well, the ignition issue was definitely the tfi. The wire looks like it melted ages ago and just now finally corroded in two...
    Oct 2017
    south-central WY
    I was referring to the starter engaging when the key was turned to the run position. I should have been more specific.
    If you didn't know, the ignition switch I mentioned is notorious for failure.
    Ahh, yeah, it was the module in the end. You could engage the starter by pressing on the module. Crazy cheap POS.
