Results 1 to 15 of 15
    Default New crate motor, which one is overall good buy?
    Putting a new motor in my 79 capri I am looking for advise on what crate motor is the better buy? Was thinking 400 hp engine for a street car , looking for complete drop in and go engine advise needed!!!!!
    Are you looking at any brands/ builders currently? Are you looking to stay 302 or go bigger? Budget? How do you want to use the car (street/strip, cruiser, auto-x, track days)? A little more info will get you some great advice I'm sure.
    -Randy
    '83 Mustang GL notchback - 351w - T5Z
    '84 Mustang GT350 20th Anniversary Hatch #2808 - 302 - T5
    ''92 Mustang LX Hatch - 2.3t - IRS (in progress)
    FEP Member vdubn's Avatar
    May 2017
    Beaverton, Oregon
    I have a couple other questions... are you looking to stay with a pushrod engine, or are other engines on the table? Also, what is your budget, that has the biggest affect on the direction you go, or how far you need to take the project.
    May 2005
    Altoona, PA
    We're definitely going to need to know your budget to give any advice at all. Are you looking for 400 hp at the wheels? If so you probably want to go bigger than a 302 unless you're interested in some kind of power adder.
    But it all starts with the budget! If you want a turnkey 400 hp engine you probably need around $10k.
    408/T5/3.73's
    Grand Rapids, MI
    As mentioned, a budget number would be helpful. Also, any good 400hp engine build for a fox body vehicle starts with a set of quality and properly installed subframe connectors.
    '89 XR-7 5 Speed
    '95 SC 5 Speed
    '91 Crown Vic P72 351W
    '97 Thunderbird
    '85 Ford LTD Squire
    Looking a 347 crate motor I am putting in cobra rear suspension and new k member and all new parts for suspension , plus 5 lug hubs , a t5 tranny and new driveline looking to spend no more than 7k
    Just a good street car with upgraded independent suspension
    EDIT POST***REPLY***REPLY WITH QUOTE**********
    Today,*12:28 PM#7
    Joe caetano*
    New UserJoin Date
    May 2005
    Altoona, PA
    Quote Originally Posted by Joe caetano View Post
    Are you willing to spend $7k on the motor or is that the budget for all those upgrades? There's no way you'll get all that for $7k, in fact I think it'll be a challenge to find a turnkey 400 hp 347 without going over $7k. You probably would be able to put one together for that price but it would easily eat up all that $7k.
    I don't want to discourage you but the money goes away faster than you can imagine. When I built my motor I was shocked to find it was over $7k total and I didn't even have high quality heads, which would have added another grand.
    One other thing I can tell you from experience is that a T5 can last behind a 400 hp engine car that is street driven, but if you think you can beat on it and power shift it you'll soon find out what the inside of a T5 looks like.
    408/T5/3.73's
    I'm willing to pay 5k for good engine the tol build is about 15 k unless u think my stock 302 can get add pans to increase hp
    its a tall order. A good shortblock will cost $1800 after shipping. One that's had stuff done to it -- more like 3K. etc. Upgraded heads are required. Upgraded intake is required. Headers, exhaust, stronger transmission, better rear-end, rear control arms, etc.
    also be careful what you ask for-- a 300 HP car with properly built out chassis will completely destroy a 400HP car that's stock everywhere else.
    Heck, my 1986GT is mostly stock and I've made some very impressive cars look extremely stupid with it. Its still a lot of stock parts under the hood except for the cam, induction, and exhaust.
    Save yourself a TON of money and do an insane amount of reading before do much of anything. The foxbody cars when stock will stand up to so much abuse its hard to imagine and if you modify them wrong, you'll barely get to drive it because you'll be stuck working on it all the time.
    -- James
    My four eyed foxes:
    past foxes -
    you can easily get 400 hp with a mild 351 build
    1986 GT T Top- stock except for magnaflow cat back
    1990 LX vert- 500hp V3 and all that stuff
    2013 GT- usual bolt ons
    St. Louis, MO.
    Quote Originally Posted by mikestang63 View Post
    Looking into that for my 85 notch.
    https://lmr.com/products/Mustang-351w-Engine-Swap-Guide
    Scotty
    Past Pony's.....
    Jan 2005
    Cordova, TN
    Anything stock block 302 based is a time bomb above 400hp. The blocks are weak. You can get 4 more cubes with a stock and stronger 351w. A lot of parts swap. You would mainly need swap headers, oil pan and a/c bracket if you're keeping a/c.
    or you could just keep what you have and go for 500+ hp and 600+ torque
    https://www.youtube.com/watch?v=BYu7irteuOU
